RC51 Shock Swap...
Old Jul 23, 2005 | 11:40 PM
RC51 Shock Swap...
has anyone tried to swap an RC51 shock onto a superhawk? is it worth it?
Old Jul 24, 2005 | 10:06 AM
superbling's Avatar
Re: RC51 Shock Swap...
The bottom mount is a different design.
I've tried R1, R6, and Ducati 900 (blashphemy!) shocks with a MUCH heavier spring from a Fox TC with limited success. The R1/fox spring is pictured in my avatar.
I tried these specifically because they have easily removeable springs (no compressor needed) and they were very cheap except the duc (basically new). These were all shorter and needed a spacer since the VTR shock is one of the longest around. You need to be concerned with the reservoir location and it's relation with the battery box and/or frame. The R1 reservoir bottom juuust touched my hugger on full extension.
They were better than stock but ultimately not ideal as I was having to run the adjustments in the upper range (solo, 165lbs). Currently I'm running a penske from a 954, also with a spacer, that's much better.
Ultimately, I want to have it revalved specifically for me and add the hi-low speed damping option to it.
eezz
Jun 13, 2012 04:51 PM
eezz
May 12, 2012 12:34 AM
98ILVTR
Jul 7, 2010 10:53 AM
residentg
Apr 13, 2010 03:07 AM
FL02SupaHawk996
Jun 11, 2008 05:15 AM
