Quick Exhaust Question
Bike is jetted for Yosh low mount RS3 slipons, would a change to Leo Vince high mounts require a re-jet?...
Not likely...the change from stock to yosh by itself didn't require a jetting change.
Originally Posted by drew_c14
(Post 142087)
Also, to add to this question (hope you don't mind Oahu), but I have standard mount pipes on, is it possible to order the high mount pipes, or would you guys fabricate high mount pipes? |
The SH is more sensitive to intake mods than exhaust mods. You can put aftermarket exhaust an still run stock jets, but if you put in a K&N filter, you must rejet to get it to run right.
It is recommended you rejet for any mod, but not needed for exhaust. |
Originally Posted by lazn
(Post 142362)
| All times are GMT -7. The time now is 06:59 AM. |
