Pics are in my gallery
Here is the link:
https://www.superhawkforum.com/galle...to=752&cat=500
New items:
- 2-1 exhaust
- PVM magnesium wheels (powder coated red)
- 1996 CBR 900RR forks (with RT Gold Valve kit and Ohlins 0.90 kg/mm springs)
- All ***** tapered roller bearings (steering stem)
- 1998 CBR900RR brake calipers with HRC hard bite pads
- Triumph 955 Daytona 955 front fender with mounting hardware
- Helibars for Daytona 955 (modded: welded 1.5" rise to them)
Still waiting on:
- ZX636 radial front brake cylinder
The result:
Simply awesome!!!!!! First of all, I LOVE the look!!!! The front end feels much more solid and planted. The damping and spring rates and perfect and wheels (shock is a RT-modded stock unit with Hyperpro progressive spring) are glued to the ground. The bike feels much more composed than before. I rode through some of Quebec`s finest "paved over cowtrails" yesterday and even in big bumps the suspension settings are perfect (no pogoing,...). The brakes are awesome: the combination of larger pistons in the calipers and HRC pads are stunningly powerful with amazing progression and modulation.
The light wheels make the bike much more "flickable" and the reduced rotating weight also makes the engine respond better. Although I did not weigh the wheels, myself and the mechanic did do a quick check with the frotn and it is SIGNIFICANTLY lighter than stock. Togehter with the strenghtened mid-range provided by the 2-1 pipe, the bike is a roll-on monster
I am VERY happy
New items:
- 2-1 exhaust
Still waiting on:
The result:
I am VERY happy
I'm interested to know once you've tested it there's a noticeable difference with the radial vs. the horizontal MCs?
Thanks,
RC
Thanks Rick,
I am somewhat curious too (mind you it works pretty darn well now to be honest). The good thing is that they are both 11/16" diameter pistons (and the same manufacturer) so the comparison won't be clouded by other issues such as size difference.
cheers
cheers
inderocker
SuperhawkForum.com News
22
Jun 26, 2011 09:00 AM
