PENSKE SHOCK SPRING RATE QUERY
Can some tech wiz guy let me know the spring rate I need on a VTR penske shock for a 190lb rider & sometimes 2 up street touring? No racetrack shenanigans. I guess I need lb/in & kg/mm
shock
just call penske directly they will tell you your spring rate.
I just got my hands on a shock of a 599 for free!!!! and it comes with a 1Kg spring rate so even though it Penske calls for a lower spring rate I am going to see how it goes. Will let you know.
Originally Posted by RacerX820
(Post 258764)
mine has the 1000 spring... my preload is almost all out but it is set for the track & i'm at 180ish lbs. regular street i may opt for the 950...
tim |
The 1000 lb shock would be a 17.9 kg/mm shock spring. This is just on the high side of the acceptable range. I am going to get the Superhawk ends put on and back the preload all the way out and see how it feels.
Also trinc what would you recomend for a front fork set up? I know with the penske the stock fron is going to be way mis-matched and the chassi will probably be all over the place. |
I am having a 17.32 spring installed on my Ohlins - that is for 200lbs street rider or 170lbs "agressive" rider. This is based on the recommendation of the Ohlins rep that I spoke with. The racetech site echoed this. 17.9 is a bit high, but not unreasonable so. The stock SH shock has a 16.40 spring. Try it out before you spend any money.
As for the forks, I am running .90 racetech springs with 7wt oil, 135mm level. At some point I will have them revalved. The.90 front matches the 17.32 rear. JB |
I calculate a 959lb/in spring rate for a 190lb rider. Since you can only get springs in 50lb/in increments, I would normally suggest a 950lb/in rate for you. If you are really aggressive or run the bike on the track a lot I would go up to a 1000lb/in part.
For what it's worth, Penske has the following recommended spring rates by weight: 160-190lb = 950lb/in 190-225lb = 1000lb/in You are right on the border, but I would still go with the 950lb/in. |
(Post 257183)
Can some tech wiz guy let me know the spring rate I need on a VTR penske shock....... Check out the Penske site: http://www.penskeshocks.com/Motorcycle-Spring_Chart.php Rex |
| All times are GMT -7. The time now is 09:24 PM. |
