move the battery
Hi guys !
Somebody does he moved the battery to lower the centre of gravity ? Do you have some pics ? Thx ! |
Actually, the battery is positioned practically right in the bike's center of mass. I know some RC51 guys relocate their batteries but I don't know where it is mounted on their bikes. I went with a lighter battery YT12A-B which saved about 2 lb if that helps at all.
Originally Posted by mikstr
(Post 191606)
...I know some RC51 guys relocate their batteries but I don't know where it is mounted on their bikes.
http://img91.imageshack.us/img91/892...1073246vy0.jpg http://img91.imageshack.us/img91/200...jpg/1/w320.png
(Post 191606)
This is the stock battery :
Bike : VTR 1000 F Superhawk 1000 cm3 1997 - 2000 Manufacturer : Yuasa #mod : Ytx12-bs - X4 Voltage : 12v Capacity : 10ah Dimensions : 150mm x 88mm x 130mm (LxWxH) Weight : 4.1380kg This is the battery that recommended me Mikstr Bike : TL 1000 R 1000 cm3 de 1998 à 2000 Manufacturer : Yuasa #mod : Yt12a-bs - X6 Ss Entr. Acide Voltage : 12v Capacity : 10ah Dimensions : 151mm x 87mm x 106mm (LxWxH) Weight : 3.2760kg This is the battery recommended for thorstens battery relocation mod Bike : CB 600 F HORNET 600 cm3 de 2002 à 2002 Manufacturer : Yuasa #mod : Ytz7-s - X5 Voltage : 12v Capacity : 6ah Dimensions : 113mm x 70mm x 106mm (LxWxH) Weight : 2.2000kg http://img412.imageshack.us/img412/664/dscf0876jh8.jpg http://img412.imageshack.us/img412/d...jpg/1/w320.png http://img386.imageshack.us/img386/3379/dscf0877bh6.jpg http://img386.imageshack.us/img386/d...jpg/1/w320.png https://www.superhawkforum.com/forum...G%5D%5B/URL%5D http://img412.imageshack.us/my.php?i...scf0876jh8.jpg |
you will gain more of an advantage by losing 5lbs by going to the gym than you will from that mod. plus you are opening yourself up for undue corrosion on the battery. i cannot think of a worse place on our bikes for a battery. Seriously it is right under the rider in the center of the bike. it doesn't get much better than that. like i said, skip the dessert and it is like the battery is not even there.
Originally Posted by REDVTR1000
(Post 191791)
Originally Posted by sassage
(Post 191947)
but nobody wants to work on themselves....just the bike ;)
(Post 191948)
Ahhh... America
Another thing to note... That's a 600... An inline 4... A twin with two great big cylinders is a bit more mass to convince into motion while starting... It might seem trivial bit 7 vs 10ah but belive me it's not...
Moving the battery somewhere else would help for an undertail exhaust setup though, were one so inclined...
Yea, but that's a scary place for a battery. Hard to secure, easy to whack with a curb or something and would need one hell of a strong mount if you do any wheelies. There would be a lot of g-forces in front of the engine when you set it down...plus it will always get wet. Oh, and it is right against the engine and header.....
If you are looking to relocate it simply to help the center of gravity, it's a poor idea. If you are trying to relocate it for some sort of a mod...find a better place. |
(Post 191947)
