Koso Rev counter help.
Has anybody used the rx2nr Rev counter.
Its a koso unit from america. Seem to be just what I wanted apart from Im having issues with getting it to read correctly. Its bouncing around like a fat bird at a donut stand. I have taken the counter feed off the ECU. Im told that a feed off each coil will give a better result. But im not sure what wire to join it to?https://www.superhawkforum.com/forum...unter-3556.jpg |
Originally Posted by reg1972
(Post 327040)
Its a koso unit from america. Seem to be just what I wanted apart from Im having issues with getting it to read correctly. Its bouncing around like a fat bird at a donut stand. I have taken the counter feed off the ECU. Im told that a feed off each coil will give a better result. But im not sure what wire to join it to?https://www.superhawkforum.com/forum...unter-3556.jpg If it still does it after your try to fix it, try installing a capacitor on the ground side. I had an Autometer tach that was doing that on a VW, and it helped. |
