Jet Kit Installation
How hard is it? I have a factory jet kit sitting in the garage and I would like to install it but have never done this type of work before. Does anyone have a good step by step on how to properly do it?
I would give it a 3/5, 5 being a job required by a technician. Make sure you take your time with it. Also make sure not to confuse which gas line goes where at the fuel petcock.
Wow you are lucky I just rejetted my bike yesterday, all this knowledge is fresh.
How to Rejet your carbs: 1: Remove the seat 2: Remove the tank bolts (front and rear) 3: Turn off the petcock 4: Disconnect all fuel lines, overflow lines, vacuum line and the electrical connector at the rear of the tank 5: Remove the tank 6: Unscrew the airbox lid 7: Remove the velocity stacks 8: Unscrew the bottom of the airbox (8 screws) 9: Disconnect the front and back crankcase hoses from the bottom of the airbox 10: Remove the PAIR hose from the bottom of the airbox 11: Remove the airbox 12: Loosen the carb boots and remove the carbs partially 13: Remove the choke cables 14: Remove the throttle cables 15: Remove the coolant lines 16: Remove the carbs 17: Remove the coolant hose that runs between the two openings on the bottom of the carbs Once carbs are off, do the following on a workbench, OUTSIDE, with places for small parts: 1: Drain the bowls using a flathead screwdriver (don't forget to close them back!) 2: Remove the bowls (3 screws) 3: Replace the main jet (only remove the jet with the flathead screw slot) for each cylinder. Factory will tell you which jet goes in which cylinder. 4: Replace the bowls 5: Remove the round black vacuum covers from either end of the carbs 6: Pull out the neoprene gaskets and each slide 7: Remove the interior plastic piece from each slide (the easy way to do this is use one of the vacuum cover screws and screw it partway into the screwhole and pull GENTLY with some pliers) 8: Remove the stock needles, keep the washers 9: Replace the needles with the factory needles after you have put the circlips and washers on the notches where the instructions tell you 10: Replace the plastic piece 11: Gently put the slides back into place 12: Put the neoprene vacuum gaskets back into place 13: Change springs for the factory ones 14: Replace black vacuum covers Piece of cake. 1 hour tops. To install, just follow the directions in reverse order. Points of note: i) Depending on your particular setup, Factory MAY suggest that you use their drill bit and drill a small hole into part of your slide to make the slides work differently. They give you a guide and show you exactly what to drill and where, so that's pretty straightforward. ii) Be careful with those neoprene gaskets, you are working with needles and screwdrivers and all kinds of other non-friendly parts. Any perforation into those gaskets will render them useless, and those are not fun parts to replace. iii) If this sounds too complicated to do yourself, it probably is, and you should let a professional mechanic do this for you. |
Re: Jet Kit Installation
holy crap :shock: that's a lot of steps. I'll give a shot
I've got a tuning wiz installing my Factory jet kit on a Dyno, in the next couple of days...
How was your first impressions after riding the bike, Loco? Did you change the airfilter as well? |
Originally Posted by Sgt Rock";p="
(Post 19110)
holy crap shock that's a lot of steps. I'll give a shot
1. Take out the old stuff. 2. Put in the new stuff. :lol: |
Drilling???? With a Factory kit?? I know that dynojet requires drilling but not the Factory kit.
May require drilling. Depends on what setup you are running. Mono, my initial reaction was holy crap, there's no more stumble, it runs clean through the rev range, even from idle. I didn't change the airfilter initially, and only recently have I switched to a K&N. Here's the catch: The genius that shipped me my filter didn't send the blockoff pieces for the underside of the airbox. Rather than go the easy way and buy them from K&N, I just jetted a bit richer on the mains and slows. I'm running 195/190 mains and #50 idle jets. Its been abnormally cold here in Dallas, so I haven't been able to ride it very far for a test, but the new jetting seems to make the bike ride very differently. Can't say yet whether it's better or worse, just noticeably different.
195/190, wow. These are much bigger than my Factory jets. Are you sure you are not running the Dynojet kit, because that's what they run. I am running 182/185 and it feels perfect.
Yeah I know. I had to compensate for all the xtra air getting through the bottom of the airbox. I'm going to start a new thread with this setup.
:roll: :roll: :roll: :roll:
Doh...! I've already phoned the guy dynoing my bike & rejetting & quoted the 195/190 formula, telling him the guys in the States (that know what their talking about :wink: ) reckon this is the go! Ohwell, if its too rich, he'll pick it up on the dyno & adjust it accordingly. I'll let you know what the outcome is in a few days. He's putting either a K&N or a BMC air filter in too! |
| All times are GMT -7. The time now is 04:47 AM. |
