Help with FP star kit; hit a snag
Old Aug 12, 2013 | 08:09 AM
HawkRider98's Avatar
Installed the kit yesterday. Very straight forward and seemed easy enough. Shifting through the gears to check installation, the shifting jams up. If I remove the arm and spring and shift while spinning the rear wheel, shifting stills seems to jam up. Will check with FP later today
Could somoneone explain to me how the shifting mechanism work? At the top of the spindle plate is a spring loaded fork. When I go through the shifts, this fork never moves. I figure since it is there it must have some use, but I can't see what. It doesn't seem to touch anything.
Thanks for any help
Old Aug 24, 2013 | 02:21 AM
jcvtr's Avatar
jcvtr is on a distinguished road
did u pull in the clutch while spinning the rear wheel.?? maybe cable tie ur clutch lever down and try spinning/ shifting again.
Old Aug 24, 2013 | 08:42 AM
KCCO's Avatar
How many gears can you select before it "jams up"? If I'm not mistaken the gear box on the SH is not made to be able to shift without the engine turning. Same reason why you want to down shift as you come to the light and not once you have stopped. Can you throw it on a saddle lift and turn it on and then try to run through the gears with the engine running and possible have to work the clutch like you are riding it?
Old Aug 24, 2013 | 09:01 AM
thetophatflash's Avatar
Would advise not runnning until you have diagnosed the assembly problem. You can shift it fine without running. A little bump of the rear tire while on a rear stand should allow the selection of the next gear.
Old Aug 26, 2013 | 06:34 AM
98VTRrider's Avatar
I agree with thetophatflash, pull up an engine diagram and make sure all the parts are in the correct places.
Old Aug 26, 2013 | 07:09 AM
FP suggested turning the clutch mainshaft a little after the shift, which worked. That was confusing, because the instructions say to keep the mainshaft from turning. It was a straight forward install, stopped at this point until I talked to FP, went through the gears and buttoned it up.
Evil_Twin
May 24, 2015 05:50 AM
bpw
Jun 30, 2014 09:46 AM
Acecool
Nov 1, 2010 08:12 AM
spladle160
Mar 11, 2010 06:47 AM
inderocker
Feb 19, 2010 09:23 AM
