front end upgrade
Old Nov 7, 2005 | 07:26 AM
woodman's Avatar
woodman
front end upgrade
Will the triple clamps and forks from a 02 F4i fit on the SH? I see it has 43mm forks and is fully adjustable. If the forks are the same length this could be fairly easy swap for improved front suspension.
Old Nov 7, 2005 | 07:57 AM
superbling's Avatar
Woody, I don't know but.....
I would bet that it would. I know they bolt on to VFR's although a popular mod with them is to only use the f4's internals to save $$$.
If I ever do a front end mod (I have racetech/brace) it would be the F4i. Not as much bling as an USD but cheaper and easier plus you can run VFR bars (02-present) or I could keep using my superbike bar kit.
I'm "pretty sure" the superhawk wheel/rotors/axle would fit bu you'd need an f4i fender.
Surely someone has done this.
Old Nov 7, 2005 | 08:22 AM
woodman's Avatar
woodman
Re: front end upgrade
Yeah, when I was looking at the F4i yesterday the front axle and wheel looked the same. Even the adjuster on the rear axle and the rear axle looked the same.
The triple clamps looked the same as far as design.
Hopefully someone has done this and has more info.
Fuzz_AZ
May 15, 2010 12:09 AM
seroj
Mar 17, 2010 11:17 AM
fundgh
Feb 28, 2008 06:44 PM
ali_squidz
Sep 13, 2007 09:56 PM
Speed_Demon
Feb 2, 2006 09:00 PM
