Front end conversion idea - thoughts?
Hey guys... This is my future plan for my front end upgrade. Regardless of your opinions on this particular conversion, please share with me whether my plans have any holes or problems... Right now it's just a theory, but i think this could give me a nice, budget front end, with powerful brakes, maintaining the narrow front fork spacing to clear the fairings...
93-97 cbr900rr triple clamps 98-99 cbr900rr fork tubes Cbr600f3 17" front wheel Cbr929rr brake calipers 97-98 Cbr1100xx 310mm wave rotors Thanks! James |
should work, though you may have to shim the calipers or rotors slightly....900RR forks work very well on the VTR.... don't forget to get a decent MC (preferably radial) for the brakes (a late model OEM Ducati/Brembo works very well with 929 calipers....)
Good luck :) |
If I was going to do it which Im thinking about is go CBR1000 USD or GSXR USD. If Im going to do it I want to do it properly. My thoughts are if Im going to do it may as well do it right.
I reckon a stock fork with a brace is is just as good as a CBR900 fork. |
i too wouldnt bother with the 900 stuff . a good 04-15 blade front end be best . why replace old out of date suspension with old out of date suspension.
i have a full 929 blade front end on mine as i got it free . if i was to do it again id have gone for the 06 front end and had the forks revalved and new springs . |
I say go for it!
its how I did mine at 1st. the bike is old and outdated. why should the rest be any different? I will add...those forks do have a good bit of stiction. |
The bike has "tune flex" so forks that are not uber stiff (rwu) may be the best call......900rr are still very good forks when done up right.
They were good enough for the Moriwaki race bikes.......
Originally Posted by mikstr
(Post 381690)
(Post 381690)
Not sure about that. There are multiple threads talking about someone fitting a USD Paoli fork years ago and finding it was too stiff for the track... Not to nay say anyone doing a usd conversion....
To get this thread back on track: I was just wondering if anyone saw any PROBLEMS.sith my wish list... Like if something doesn't fit right or something... Not really looking for critiques on whether it's better or worse than a USD setup... :) James |
Originally Posted by NZSpokes
(Post 381697)
As these were made to look like factory bikes they couldn't fit USDs.
now then, back to the topic at hand, the only possible problem would be regarding spacing the rotors in relation to the caliper. However, the fact that you are using axial calipers (instead of radial mount) does give you some provision for making adjustments in this regard so it shouldn't be difficult to overcome, assuming it even is an issue... |
James |
(Post 381698)
To get this thread back on track: I was just wondering if anyone saw any PROBLEMS.sith my wish list... Like if something doesn't fit right or something... Not really looking for critiques on whether it's better or worse than a USD setup... :) James If I can hold GSXR750s off then I don't see an issue. And im a fat bugger. |
Spokes that's no logic. On a track a bike is like sneakers on a basketball court. They may be nice but all the speed is the rider.
I have beat ninja 1000s on my ninja 500. And it wasn't because the forks were any good. You should do your fork swap if that's what you want to do. I just feel like if I did that then in a couple months I would wish for CBR forks so would just do that the first time. Guessing you already have all the stuff? I mean, what about, say, this? 2002 2003 02 03 Honda CBR900RR CBR954RR CBR 954RR 954 Front Suspension Forks Set | eBay tempting, huh? |
Yeah that is nice...
I really won't be diving into this until next winter... This winter was lots of powdercoating, and hopefully tires. James |
(Post 381706)
I have beat ninja 1000s on my ninja 500. And it wasn't because the forks were any good. I feel the same about the brakes, with HH+ pads and braided lines the thing stops brilliantly. Ton of feel and power. |
Its not the Hyosung's. Its the spotty, utterly fearless 14-16 year olds on them.
Lol...
1 Attachment(s)
Take into account the ratio of MC to caliper. This thread has dimensions of common swap MC and calipers.
https://www.superhawkforum.com/forum...ke-mods-13176/ Also here is a chart that might be helpful. Attachment 18149 |
Originally Posted by xeris
(Post 381717)
Originally Posted by Kieran
(Post 381712)
lol:rotf:
It was worse when they were riding RG150's. With their little narrow tyres (castoff 125gp slicks) and a fearless rider they held a really disturbingly high corner speed... If you followed them close enough you could see the rear end pogoing through the loop at Teretonga as the cheap suspension loaded up and unloaded. No wonder them nappies were full...;) |
As for the threads original question, I think it sounds like a great idea. Lot of people have gone the 900rr forks route, and there's not much people have to say bad about them.
What size was the original disks on the 900rr? or the 929? You might have to put the thing together to find out what size disks you need, or if you have to put the caliper on a spacer plate to match the disks you have... I would be tempted to use the 900rr calipers, so you know what you are working with from scratch. I am putting ZX10r forks on mine, using stock calipers, so I know I 'need' 300mm disks from scratch. I am using the stock VTR front wheel, so I should be able to get away with the stock 298mm front disks... |
Kieran, ZX10 forks with stock vtr calipers? I think thats extremely difficult. Two totally different mounting as one is radial.
Stock ZX10r calipers. My bad:rolleyes:
