F4i Front wheel
Anyone know off the top of their head if the F4i front wheel I have is of any use with either regular SH forks or with USD forks from an SP2? Already has no bearings so changing them is not as much of an issue as proceeding without them might be. This wheel should he considerably lighter than the stock anchor and it will therefore certainly wheelie even easier,especially with a Pure spooned on... and since the Michelins are perfect from the factory imagine how much better it will corner with no wheel weights needed!
Originally Posted by RIPI
(Post 299560)
(Post 299560)
Originally Posted by 8541Hawk
(Post 299601)
Sorry bit no it will not fit either set of forks you have listed.
Care to expand on that just a little bit?? Anyone need an F4i wheel with or without rotors and a decent Q2 mounted? |
F4 Front Rim, 6 Spoker
I have a set of USD 2006 CBR1000RR Forks that I am in the process of installing. My ? is will the F4 rim I am about to buy fit? I already have the 6 spoker for the rear. Thanks for the info, B.
Originally Posted by katryder1@gmail.com
(Post 299894)
