F4i brembo calipers fit the SH without mods?
Anyone know if a f4i Brembo caliper will fit a Shawk without modification?
Thnx! |
I've neve seen them before, do you have a photo or link?
no. but from looking around i find that whatever brembo calipers you would use on the f4i, requires an adapter bracket.
It stands to reason that you should be able to make it work if you have the bracket.
FWIW the Nissin F4i calipers / MC are pretty good. Add SS lines and nice pads and the are more than pretty good and probably cheaper than Brembos, but not nearly as cool.
Well, logic dictates that since stock f4i calipers work with a tiny mod then all that works on the f4i should be the same... Unless their design makes it impossible to mod them in that way...
