Did I forget anything for my shift mod?
My computer wont let me ad to my post. So I've made a new one.
I'm installing a FACTORY PRO full shift kit with shifting star. I ordered from RON EYERS a R/H clutch cover gasket. A water pump gasket. A clutch hub lock nut and the washer that sits behind it. I have a tube of Kawibond adhesive. Some grease and red locktite. I purchased a clutch basket holding tool from Cycle Gear and have four quarts of synthetic Castrol, a filter and a gallon of 50/50 coolant. I also have a new radiator cap. Honda. I plan on draining the coolant and oil before I open up the engine. Anything I've forgotten? |
Originally Posted by ZERO
(Post 392497)
I forgot what a touchy subject that is.
It's also taboo on the KAWASAKI ZX1441R site. |
What's wrong with synthetic Castrol? It's the best oil on the planet with the exception of the oil that I use.
Originally Posted by VTR1000F
(Post 392510)
It only took a couple days and I have parts that are no longer made. Thumbs up to them |
(Post 392522)
For the record. I just received notification that my Factory Pro parts already shipped.
(Post 392600)
FP still lists the EVO-7 Shift STAR Kit (PN: SHFT-EVO-HON-77) as being available ..... but they say FP is slow to ship to resellers and it could be a month.
For $200 more or less it better be a @#%@* automatic transmission.
How different is the shift star and arm than stock? Where's JackFlash when you need him? |
I second this vote... Let's copy it and call it the Chinese shift mod...
James |
Originally Posted by AndyMX47
(Post 392717)
It is incrementally better, just like adding Jamie's shifter makes it incrementally better, or modifying Jamie's shifter for custom fit bushing makes it incrementally better. But no, it is not making it anything as slick, or "automatic"
(Post 392717)
The index wheel is cleaner, smoother and of different ramp contour. Tons of pics on line comparing the two... should even be some here on this site. |
I completely understand the parts and the affect each part has on the bike - it seems really expensive, that's all. It would be nice if we could get the shift arm with the bearing end on it for say, $50. I suppose the low production numbers are what jacks the price up.
OCMD I guess! |
(Post 392732)
OCMD I guess! The shift star and the arm/spring are sold separately. Though they work together directly and I don't see the usefulness in doing just half the kit. Yes, powersports parts are always pricey, even for like items in the automotive world. Look at an exhaust system. for what a quality header and muffler costs for a mainstream motorcycle I could have a top of the line header, SS tube and high end PAIR of mufflers for my Shelby or Mustang INSTALLED...:mad: Fasteners are the same... I love shopping at ProBolt but the prices kill me,,, and there is no reason.. it's not material, and its not machine time costs. The parts are not complex and any journeymen CNC machinists can program his CNC machine to make a bolt. |
(Post 392722)
Do you think Jamie's shifte lever is worth it, given true heim joints are installed in the linkage? Also, did you install a bushing or bearing in Jamie's lever, and how and what exactly did you do (I could not find a link to where you may have discussed this before and provided this info)? Thx, Bret |
I kept the stock shifter and added a bushing, also shimmed the shifter on the bolt so there is no play, and changed to heims and the early model aluminum linkage rod...
It shifts like a different bike now. Not that you asked me :) James |
(Post 392722)
(Post 392742)
Erik, don't forget only the very first run of shift levers had the Teflon bushings - that was quite some time ago. The vast majority we have made had ball bearing pivots which is the design today.
If I put the SH back on the road, I'll need a new shifter (and most of the right side :mad:) |
It's installed and it's one of the best mods I've ever done on any bike!!
It shifts SSOOO much better. |
(Post 392742)
2 Attachment(s)
Originally Posted by Twitchy
(Post 392862)
I am intrigued by this shifter. I hear a lot about it but have never seen a picture. I am assuming Jamie you are Daugherty Motorsports or associated?? Checked the website for this shifter but not listed, so I thought it was a discontinued item. Are they still available?
Send him an email and ask about the shifter jamie@daughertymotorsports.com Here are two pics of the shifter.. You can also see the rod end modification I did to the link rod. https://www.superhawkforum.com/forum...1&d=1452817245 https://www.superhawkforum.com/forum...1&d=1452817247 |
It doesn't look like that these days. The design has changed. I'll post some pics tomorrow.
3 Attachment(s)
Here's the current design as of last September. This is how it came from Jamie; I haven't added any hardware. Be sure to specify which type of link rod you have so he provides the appropriate Heim joint rod end - male or female.
JD,
What's a shifter running these days? $$? |
Hey 102, word on the street is that Jamie is currently not in the US, so be patient on a reply.
Originally Posted by 102dals
(Post 397078)
JD,
What's a shifter running these days? $$? I don't like to post prices because they are subject to change. Feel free to check out my site for the latest pricing details. For items that are not shown on the site (like these shifters) feel free to drop me an email. Thanks! |
| All times are GMT -7. The time now is 07:34 AM. |
