completly debaffled?
I completle gutted my stock exhaust and cut them down about 7 inches and it is loud like i wanted. Will i have any harmful lean or rich conditions i should worry about?
might be a bit lean
nothing a needle shim can't solve |
I just took off down the road and its too loud my ears were ringing so its back to the regular baffelectomy pipes till i can afford some pipes or the ducati 848
We could maybe work out something on my Jardines.
Originally Posted by 05xman
(Post 179897)
Pipes might be a little cheaper than an 848, im not sure though....:p |
Originally Posted by nuhawk
(Post 179929)
Originally Posted by cal2az
(Post 183244)
definitely gonna have to say you'll reach pipes alot sooner than a duc.... unless your on your hawk then you'll get a duc quicker........... FROM THE REAR! |
well today I put the fiberglass back in and welded the end caps on and bolted them up. I like the end result. now some grinding and alot of sanding ( I cant weld worth a damn) and they will look good. :D
(Post 183244)
Ha! Yeah, if he buys me a Duc 848, I'll buy him any pipes he wants, and throw in all the pizza and beer he can consume! |
My Hawk is set up as a sport tour. With the PAIR valve operational, the combination of the loud pipes and the occasional explosion as I stopped was too much.
I went all the way back to stock pipes. Sheesh!! The bike sounded like a TORO lawnmower. Since then, I added APE CCT's and eliminated the PAIR valve (thanks to the forum for the good How To's!!) The baffelectomy pipes aren't nearly as loud as I remember them and , so far, the explosions are gone. Tom |
| All times are GMT -7. The time now is 04:05 AM. |
