Clipons for USD conversion
Hello, I'm trying to collect the parts needed to install usd forks on my vtr. I only miss front wheel, axl, rc51 top yoke and the clipons.
I would like to know what kind or brand of clipons did you use with standard fairings το convert your bikes in order to start searching on ebay. Thanks in advance!! :cheers::cheers: |
lots of options - you should search for some experiences. Give some more info on what you are looking for also - do you like the leaned over down-low feel? or want something more upright? I used convertibars for awhile and just recently took those off to replace with a simple modification to allow bar risers and a tubular style handlebar. But others have posted their experience. Just search for RC51 front end as a start
cliby... thanks for your reply.
I'm looking for low clipons, the bike will be used as a track day bike. May run in an endurance (after some engine modifications and a full exhaust) and probably a race (twins), so I'm looking forward using the lowest clipons that can fit using standard fairings. If I wont be happy I have found a set of full fairings from a German manufacturer that gives you space to use really low clipons. But I'm not into giving money for fairings (I like the look of it) unless I cannot do otherwise. Thanks again:) |
The lowest possible to mount is the helis for the 929/954 without mods to the fairing I think... Slightly below stock...
Thank you tweety... now the hard thing is to find a used set.
If anyone else knows any other brand please inform! Thanks! |
