Chain / sprockets - recommendations & where to buy?
Old Jul 8, 2009 | 04:11 PM
SD Hawk's Avatar
Replacing with a 530 o-ring 16/43 gearing.
Any brands recommended, any brands to avoid?
Also, who has the best deals?
Any feedback is appreciated!
Old Jul 8, 2009 | 06:52 PM
mboe794's Avatar
I always thought JT made pretty good sprockets. I've used many of their aluminum ones on my motocross bikes. I put a steel JT on the hawk toward the end of last season. It is already near the end of its life. I think I'm gonna go back to sunstar the next time around. The stock sunstar lasted for a very long time. I would not recomend a JT, at least not on the SuperHawk.
Old Jul 8, 2009 | 06:59 PM
AFAM or Supersprox are both good. JT are not bad.
So here's the question of the day: When you changed out your sprocket last fall did you also change the chain as well? If not, that's the problem. ALWAYS change chain and sprockets at the same time. Otherwise you will accelerate the wear on both.
Old Jul 8, 2009 | 07:13 PM
mboe794's Avatar
The chain was not new, but very close to it. I rode on it for a month or two before deciding to add two teeth to the rear. If the used chain had anything to do with it I'd be surprised. Maybe I just got one out of a bad batch of sprockets.
Anyway, my opinion is that Takasago RK chains are the best.
Old Jul 9, 2009 | 07:06 AM
98ILVTR's Avatar
Just got a DID X-Ring Chain, and run with JT Sprockets. Everything is fine, and I really enjoy the chain!
Old Jul 9, 2009 | 07:27 AM
Little_Horse's Avatar
2nd mouse gets the cheese
Anyone else have any issues with sunstar rear sprockets? I am pretty sure mine may have an elliptical shape as the chain will go tight and loose as you spin the rear wheel. Seeing as the chain is still pretty new and I take good care of it I don't think its sticky links. Anyways it would only have to be out of round a little to cause this to happen. Just wondering if sunstar makes cheap sprockets that aren't toleranced as well.
Old Jul 9, 2009 | 09:07 AM
swordfish's Avatar
sounds like normal stretch spots on the chain to me. your chain will get those as its broken in. I think most of us have that. there are always spots on the chain that are looser or tighter than other spots. just remember, when you go to adjust, use the tightest spot on the chain as a tension reference. you're chain can be a little too loose, but it can't be too tight.
Old Jul 9, 2009 | 09:28 AM
thanks, so no worries. Good to know.
I have a DID chain sunstar sprocket combo I paid $130 for. Only thing is you could only get stock sized sprockets with the kit. The chain is great and the sprockets seem to be holding up very well against wear and tear.
Old Jul 9, 2009 | 09:48 AM
L8RGYZ's Avatar
DID X-ring or nothing.
I've used RK, Tsubaki, EK & Regina... nothing has come close to lasting like DID. My OEM DID chain lasted 50,000 miles. Put a new DID & sprockets on about 5,000 miles ago. Never had to adjust for stretch, even in the first 4,000 miles. It has only been adjusted when I put a new tire on.
Rollin20z
Jan 28, 2013 02:42 PM
Pixtaker
Jun 6, 2010 03:52 AM
CNI Dawg
Jul 4, 2007 05:19 PM
davidhartley
Jun 24, 2007 03:16 PM
CNI Dawg
Jun 8, 2006 10:22 AM
