Carb A/F Adjustment for Altitude
I just moved from Manassas, Va, altitude is 300 feet ASL, to Boise, ID, which is 2600 feet ASL.
My question is will I need to adjust my A/F mixture leaner to compensate for the altitude difference? |
What are you running right now? How well does she function? I don't believe that altitude difference requires changing jets with a stock setup... it already runs just a tad lean.
FP 1.0 carb kit and 4 degree advance. I ahve not had an opportunity to ride the bike yet to see why she performs.
Not really..... you might need to turn in the pilot screws a 1\4 turn or so but that would be about all you would need to do for that amount of change.
So just ride it and if it feels a little flat or vibrates a bit between 3-5K then tweak the pilot screws..... ;) |
