Carb Confusion
My 97 Euro model SH has the stock air filter, Scorpoin high pipes with baffles. I have shimmed the needles .030+.040, 48 pilot, and plugged one front slide hole
and blocked off PAIRS as recommended by 8541Hawk. It runs OK but too rich and gas mileage is 25% less. The problem may be that it has different model carbs than US models:VTPOB instead of VTP1A(Cal.)VPT2A(49state) and different needles:front A1UD,rear A1UC instead of A1UF,A1UE. My bike came with 45 pilots were were changed to 48s in 98 but the carb model changed also. I had the idea to remove the shims, leave the 48 pilots in and the plugged slide hole. If anyone has any ideas, or has experience with this carb confusion I would appreciate your input. Thanks |
Whats your main jet sizes?
carb confusion
the mains are stock : 175+178
Float Valves
Originally Posted by MarkN
(Post 327575)
carb cnfusion
about the pilot screw settings: a Honda mechanic in my town led me to believe that the pilot screws are air screws and that turning them out is leaning the mix
so I set them at the Honda spec of 2 3/4 turns out. I started at 2 1/4 front and 2 1/2 rear and it runs a little better I think, although I am still hoping one of you SH experts will help me get on the right track. I checked the float valves and they are OK. |
end of the thread
To answer my own question: I took the carbs off for the third time and removed the .030 + .040 needle shims, I left the 48 pilot jets in and the plugged front slide hole. The bike runs really well and now I can get on with the suspension work. I found an öhlins shock and I got a Racetech full kit for the front. Thanks for your input guys. Mark
(Post 327642)
so I set them at the Honda spec of 2 3/4 turns out. I started at 2 1/4 front and 2 1/2 rear and it runs a little better I think, although I am still hoping one of you SH experts will help me get on the right track. I checked the float valves and they are OK. Generally air screws are on two stroke dirt bikes, and most 4 stroke bikes including ever streetbike I can remember have fuel screws. It sounds like you got your issue fixed but everything you did would richen up the mixtures, so just back it off a bit and you should be good as it sounds like you've done. |
