Anyone know this piston kit?
http://japan.webike.sg/products/117608.html
Jb Power, Comp. ratio 12:1, 99mm piston, 1016cc... It's the first time that i hear about a big-bore kit (other the 1200cc of the German Factory...) |
An awful lot of money for a very slight increase in displacement (in my opinion). For that price, you can get a set of custom 0.5mm oversize (allowing you to use OEM Honda rings) JE (or CP) pistons made (to your specs). You need to order a minimum batch of 4 (with JE anyhow) but can sell off the other two. That will get you up to 1006 cc for a whole bunch less money (btw, this is precisely what I did, along with another forum member)
Of course, if you don't want the hassle and can afford it, it is likely a decent product. I have bought from Webike a few months back and received excellent service FWIW |
Yes Mikstr, i also know the 0,5 oversized piston...
But is interesting that you can increase the capacity.... for the JE / CP piston at measure, it would be interesting whit 100 or 102mm.... that would mean 1036 or 1078cc.......... but "how much" is possible the cylinder bore? And next, for the nickel? I think it's a very interesting way for gain many cv.... |
another question.... have you bored your cylinders for going to 98,5mm?!?
yes, of course
