520 Conversion Update
The 15/43 feels fantastic. I'm turning 4k rpm @ 70 (displayed). Low end accelleration is increased (did someone say wheelie?) but manageable even for this newbie. Got a second opinion on the "knock" I was hearing. All say is ok and just normal for performance V-twin. I must admit it didn't break at 155 mph so all is well for now. Or was that 55 mph... yeah, that's what it was. Thanks for the advice/opinions. Next is the stainless cables. I'll try to get pics up soon.
What 520 setup did you use (also clip or rivet?) and where did u get and what price?
I must admit it didn't break at 155 mph so all is well for now. Or was that 55 mph... yeah, that's what it was. Thanks for the advice/opinions. Next is the stainless cables. I'll try to get pics up soon.[/QUOTE]
you realize that with the gearing change, at indicated 155 you were really doing 55 right? (kidding) |
Every 1000 rpm generates just shy of 16 (15.8 actually) mph in top gear with 15/43 gears.
Originally Posted by mikstr
(Post 49252)
https://www.superhawkforum.com/forum...1278#post31278 |
I purchased the exact same set-up after reading that post of yours. Definitely the best deal I've found. I went with a 530 chain and sprockets though. Cost a little extra but I'm hoping to get a little more life out of 'em, and I'm not too concerned with the weight yet. Need to put a few more miles on the bike before I can justify the need to drop chain and sprocket weight. I'm at school now and don't have the tools/time to put them on so I'm anxiously awaiting the end of the semester so I can get home!
I'm about to do a 520 conversion this weekend. I went with a DID chain and 15/43 JT sprockets. Can anyone tell me if the front sprocket has a standard or reverse thread?
Thanks! |
Originally Posted by rideawn
(Post 49249)
Originally Posted by SD996
(Post 49261)
Thanks! |
jt 15/43 here. mt conversion went well with rk rivet chain here. my 15 yr old daughter installed it while I "helped". You wont have a problem. I went and purchased a garman 33 GPS has MPH while viewing map. solved my speedo problem. I had to get it for my trip to Sturgis from NC this Aug. Hope you enjoy as much as I have.
I ordered my 520 conversion kit two days ago....went with teflon coating for the extra 20.00.....the wait time does suck though!
| All times are GMT -7. The time now is 06:36 AM. |
