Rear turns.....
Hey can someone clue me in on how to remove the rubber section of the rear turn signals. I want to move them in closer to the bike, but am having a hell of a time with that section.
Little help maybe? Thanks!!! |
You have to remove the bulb housing from the end shroud and wiring from the stalk section, once this is done there is a phillips screw located down the hole where the wire feeds through holding the rubber base to the bulb shroud.
