PASS SEAT COWL GAP, SOLVED?
i haven't heard anyone mention this in quite some time... but what is the best way to close the gap between the pass seat cowl and the tail fearing. i just switched seats to a corbin and that amplified the gap. i sused some washers between the two phillips screws, under the seat and their mounts and that took up alot of it, but is there a way to colse the gap more... any ideas... i will try to get some pics soon. thanks!
...BUMP...
I just noticed that the very back of the seat cowl is higher up with a sargent seat than with the stocker. To me it seems like its because the seat pan on the sargent is much ore flexible than the stocker it will lift a bit at the rear since its secured in the latch near the farther forward. Going to try the washers mentioned above. But might also look into stiffening the pan somehow in the passenger area. |
