SuperHawk Forum
-   Modifications - Cosmetic (https://www.superhawkforum.com/forums/modifications-cosmetic-34/)
-   -   Pappy Goes Cafe. (https://www.superhawkforum.com/forums/modifications-cosmetic-34/pappy-goes-cafe-26632/)
PappySmears Sep 24, 2011 05:49 PM
5 Attachment(s)
Seat welded up and now sitting on the frame,, starting to like it a little more. I think I will screw the tail light to it and see how it comes up..
Any criticism is welcome , I have only beer to give me inspiration, I am flying blind here boys!!
Attachment 25560
Attachment 25561
Attachment 25562
Attachment 25563
Attachment 25564
msethhunter Sep 24, 2011 06:49 PM
Not feeling it. The rear portion needs to be more rounded.
PappySmears Sep 24, 2011 08:54 PM
Unfortunately I need the use of a tool called a "english wheel" which I have not got to roll the tail on the other axis:(
mertechperformance Sep 24, 2011 09:39 PM
can't wait to see this painted and with a seat pad. I kind of wanna say don't have the tail dip down at the rear (i know you have it somewhat mimicking a fender and following that line)
I love my hawk semi naked and fighterish but never would have though to legitimately cafe it (i've still gotta finish my cb550 restomod/cafe)
PappySmears Sep 27, 2011 09:19 PM
1 Attachment(s)
Took about 2" off the back of the seat to see how it looks.
Attachment 25545
msethhunter Sep 27, 2011 09:39 PM
http://i72.photobucket.com/albums/i1...DSC00011-2.jpg
Much better. Airtech makes some nice fiberglass ones if you're interested.
Tweety Sep 28, 2011 12:21 AM
That's starting to look really nice...
erno Sep 28, 2011 07:55 PM
Good job mate
Pity you couldnt cut the btm rail on the rear subframe shorter
To me it would make the rear end neater
mikstr Sep 28, 2011 08:14 PM
Nice work. Seems we're witnessing the metamorphosis/development of a future VTRoM....
Little_Horse Sep 28, 2011 09:18 PM
Actually not true, it can be done with a teardrop mallet and a beater bag, then once its roughed out to the desired shape you can hammer and dolly it pretty smooth with a lot of patience. Its not easy but neither is the english wheel. I usually beat the shape I want then english wheel it smooth.
PappySmears Sep 28, 2011 10:08 PM
3 Attachment(s)
In doing this bike in "Cafe Racer" style I want to put Ye Ol 7" chrome headlight on the front.. Now the problem being that they dont make headlamp fork clamps to go around the 50mm 2" Hayabusa front end I am bolting up to it.
So I bought a set of cheap Chinese 50mm clip on bars and a gsx headlamp ears and milled them so they bolted together.
One side done!
Attachment 25536
Attachment 25537
Attachment 25538
mertechperformance Sep 29, 2011 02:43 AM
wish i had such tools at MY disposal...
PappySmears Sep 29, 2011 01:03 PM
Drop around with a few beers mate, and those tools are at your disposal till your little heart is content!!:D:D:D
PappySmears Sep 29, 2011 03:24 PM
2 Attachment(s)
Attachment 25534
Attachment 25535
PappySmears Sep 29, 2011 10:54 PM
2 Attachment(s)
I decided to keep the original gauges, as its a pain to fit a aftermarket gauge and have all the benifits of the orig.
So I made this bracket to hold the thing.
Attachment 25532
Attachment 25533
poppazuti Sep 30, 2011 12:08 AM
I really like where this is going. After I switched to my 929 front end, I had the same issue with mounting the 7" round headlight. The solution I came up with was using hydraulic hose clamps (already had the brackets for the headlight). $19 fix but doesn't look anywhere as nice as yours.
BBB Sep 30, 2011 04:06 PM
What sort of beer and where are you? Anywhere near Canberra? :p
msethhunter Sep 30, 2011 04:24 PM
Looks like you have the front tire mounted up now. Any fitment issues yet?
mertechperformance Sep 30, 2011 07:25 PM
those are some interesting gauges...
PappySmears Sep 30, 2011 07:31 PM
That front wheel is just the VTR one sitting in there it has a huge dent in the rim from impact damage. The interesting thing is the disc spacing is identical to the Busa, however a little snag is that the busa rotors are 320mm.
erno Oct 2, 2011 02:17 AM
This has a nice sleek tail
TL1000R CAFE RACER Ruleshaker Pays Basque - YouTube
PappySmears Oct 2, 2011 02:58 PM
3 Attachment(s)
Here is a rough gauge/headlight assemble to give you an Idea of the look the front will be using the original gauges.
Attachment 25527
Attachment 25528
Attachment 25529
PappySmears Oct 3, 2011 09:41 PM
1 Attachment(s)
Well I have now cut out the seat pan, and mounted it ready for the upholster to put a nice bit of foam and covering to. I have to say, I am not a metal fabricator, and this is my first go at making a cafe seat,,, and let me tell you it will be my last, as I have had a gut full of cutting and shaping, and I still have to make an under carriage!!
Attachment 25518
mertechperformance Oct 11, 2011 11:38 AM
updates???
PappySmears Oct 11, 2011 01:10 PM
So if you finish with a "English wheel" then in fact it would be TRUE...:confused:
Anyway, bottom line is I am not a very patient sorta guy!;)
PappySmears Oct 11, 2011 03:52 PM
2 Attachment(s)
Latest Update is my secondhand wheel arrived from ebay, now I can mount the alloy front guard and the radiator to make sure I get correct clearance with fork travel.
Attachment 25487
Attachment 25488
http://i72.photobucket.com/albums/i1...DSC00034-1.jpg
kj4kym Oct 11, 2011 04:10 PM
thats a busa front end, all you did was change the bearings and it was a direct swap?? can you post a link to the bearing. was it all balls?
supermarto Oct 11, 2011 06:33 PM
Sweet... I'm a subscriber.
PappySmears Oct 11, 2011 06:50 PM
No Mate it was only the top bearings that was different. So I took the honda bearing and the top Busa bearing down to the bearing shop and asked for one with the inside to match the Busa stem and the outside to match the Honda frame............ Presto!
lazn Oct 12, 2011 09:12 AM
FYI: All Balls will do that for you over the phone and ship you the bearings you need if you don't have access to a local shop. But if you have a local shop that is usually quicker. (just say, I am putting X triples on Y frame, sell me the bearings I need)
