Painting Completed - Seal Cowling and Lower
Old Jan 27, 2010 | 07:28 AM
Brother J's Avatar
Brother J is on a distinguished road
Temps warmed up enough yesterday to paint the seat cowling and lower fairing. Bike is now complete.
Before:
During:
After:
Old Jan 27, 2010 | 07:43 AM
Nice job! HAHA looks like my driveway my girlfriend laughs because I have the same huge garbage can and the top is covered in layers of spray paint
Old Jan 27, 2010 | 07:47 AM
cosean's Avatar
cosean is on a distinguished road
Looks mint!
Old Jan 27, 2010 | 08:01 AM
motojoe's Avatar
Sexual Daredevil
Nice.
Old Jan 27, 2010 | 08:16 AM
You could probably clean up and spray a few coats of clear on the mufflers and make 'em look new as well. I was goofing around with an old faded tbr carbon can awhile ago. Just gave it a quick wet sand and rattle canned it & it looked almost brand new.
Old Jan 27, 2010 | 09:18 AM
Little_Horse's Avatar
2nd mouse gets the cheese
That looks alot better.
Old Jan 27, 2010 | 09:34 AM
Brother J's Avatar
You must be reading my mind. I was wondering if there was some special paint to use on the carbon cans. So clear coat will do the trick, eh?
Old Jan 27, 2010 | 11:46 AM
They don't seem to get very hot but I believe I've now seen high temp paint made in clear, and that's what I'd go for. Depends on how bad the carbon is, I guess it could make it look blotchy depending if it's rubbed or dried out bad in places and penetrates deeper in some places than others. I'm sure you know more about painting than I do. Maybe mask off and test a small square on the backside of one of the cans that you can't see to try it out.
Old Jan 27, 2010 | 11:54 AM
Also if you plan on repacking them anytime soon I've added a thin aluminum shield around the packing on the couple carbon cans I've repacked. They sell it in the auto parts store and it's seems like it would help protect the carbon from some of the heat. I know some companies like LeoVince supposedly come this way from the factory. Also be careful if/when you dissassemble those cans. Unlike say Erions or M4 that have a full piece of pipe on the caps that slips into the baffle, TBR endcaps have four fragile little "fingers" that hold the baffle it place. They break easily, sometimes on their own, and will allow the baffle to drop down or move around. I repaired one pretty easily while I was taking a TIG class, but it's kind of a pain if you don't have access to or know someone as it's kind of a delicate repair.
Old Jan 27, 2010 | 01:38 PM
uchi's Avatar
Looks great man. What lower is that? There are a few but I like that one the most
Old Jan 27, 2010 | 03:07 PM
Oh and if you didn't already do so get some thermo-tec heat shielding and put in between the header and the lower fairing. Your paint job will thank you. It's self adhesive but when I did a sharkskinz I had I just painted some resin on it and it was permanent. That stuff REALLY works.
Old Jan 28, 2010 | 04:58 AM
Brother J's Avatar
Thanks, uchi. The lower is made by Shark Skinz. Good quality fiberglass and fits up nicely.
Old Jan 28, 2010 | 05:06 AM
Brother J's Avatar
There was already some heat shielding, but it was coming loose. I sprayed some 3M adhesive and it set up well. BTW, thanks for the insights into the 2Bro's carbon cans. Fortuitously, I just got a nice Tig welder (Thermal Arc 185) for my B-day and will be able to repair any crackage in the end caps. That is, after I learn the fine art of aluminum tiggery.
Old Jan 28, 2010 | 08:17 AM
steener's Avatar
steener is on a distinguished road
Did you rattle can that paint job? If so, was it the Rustoleum Gloss Cardinal Red?
Old Jan 28, 2010 | 09:01 AM
psyclown's Avatar
psyclown is on a distinguished road
how did you get ao much of the frame polished. Is it still partially textured?
Old Jan 28, 2010 | 10:58 AM
AdamK's Avatar
Always Learning
Yeah also curious about the paint selection
Old Jan 28, 2010 | 11:47 AM
Moehawk005's Avatar
98' SH stock
Moehawk005 is on a distinguished road
wow, great job. i love what you did wt it.
Old Jan 28, 2010 | 12:51 PM
The rear portion wouldn't shine if it were still textured...you have to grind it down smooth and then polish it. It's a few extra steps & a little more work than the smoother parts like the swingarm and the front portion of the frame. I did the same to a gsxr I used to own. The frame is the same-rough texture towards the rear.
Attached Thumbnails Painting Completed - Seal Cowling and Lower-mygsxr600.jpg
Old Jan 28, 2010 | 02:09 PM
Brother J's Avatar
No rattle can jobs in my garage. Well, not for this kind of job anyway. In an earlier thread, I posted about painting the fairing Honda (car) "Milano Red", after repairing some tipover damage. I wanted just a shade darker/richer than the Italian Red OEM color. Its very close, but side by side, you can see the difference. I used a base coat/clear coat system from Martin Senour (NAPA).
Old Jan 28, 2010 | 02:15 PM
Brother J's Avatar
I am the beneficiary of a very meticulous polishing job done by the original owner. He obviously cherished the bike to have put that much effort into the polishing job. Getting the casting texture smoothed out and polished is very time consuming. He also polished the rims and engine casings. 2nd owner had the bike for a year and did not keep up the level of polish, especially on the rims.
maniac2313
Jun 28, 2011 04:53 AM
archaicguy
Feb 27, 2011 11:50 AM
mikstr
Dec 18, 2009 06:17 PM
2armor
Sep 26, 2006 05:10 AM
