painted pipes
Old Sep 6, 2010 | 12:50 PM
jaypo's Avatar
jaypo is on a distinguished road
painted pipes
Been a while since I've done anything to the hawk other than regular maintenance. So after I pulled the wheels the throw on some fresh tires, the headers really needed some TLC. I'm not much on chrome either so after a lot of prep work cleaning the pipes, some high temp black went on...
Old Sep 6, 2010 | 02:18 PM
ima98chickenhawk's Avatar
ima98chickenhawk is on a distinguished road
i like it
Old Sep 6, 2010 | 02:20 PM
NH-Raptor's Avatar
That looks great! Nice choice and well done!
Old Sep 6, 2010 | 04:00 PM
That's just solid great! Whether it's red or it's yellow or blue - it should never be more than two colors - greater than that sucks. Factory could never figure that out.
What a beautiful example. Bravo!
Old Sep 6, 2010 | 04:16 PM
RWhisen's Avatar
Former Superchicken Owner
Those look nice however I think I am going to jump in with some ceramic coating for durability and to reduce some heat off of them.
Old Sep 6, 2010 | 04:19 PM
saige's Avatar
the boss
thats exactly what im thinking,i may do that than wrap them,just be using the ceramic to protect from rust and such.
Old Sep 6, 2010 | 06:25 PM
jaypo's Avatar
Good idea. I really like how the black turned out and there is a place close that does coatings so eventually a ceramic coating will be in the works.
Old Sep 6, 2010 | 06:36 PM
RWhisen's Avatar
I'm really glad he painted those so I could see how it would look!
@ Saige-with the ceramic coating you don't need to wrap them. You are supposed to get a significant heat reduction from just the coating.
Sorry for the thread hijack and they look great.
Old Sep 7, 2010 | 05:17 AM
johnpace2's Avatar
johnpace2 is on a distinguished road
Damn, that looks awesome!
Old Sep 7, 2010 | 10:09 AM
Stevebis1's Avatar
I agree, that does look good - whose paint did you use and is that a satin? semigloss?
Old Sep 7, 2010 | 07:18 PM
jaypo's Avatar
I used gloss black 500deg engine enamel with "ceramic" or whatever variant of real ceramic it is. I doubt it will last too long but I wanted to see what the black would look like. I spent good time prepping the surface wet sanding and using a wire brush to remove junk and rust, taped off the ends, and then applied two coats allowing time in between to dry. It is now curing but should be good to go in a day. I'll sandblast and have a local place ceramic coat it when this wears off.
Old Sep 10, 2010 | 08:35 PM
cales98hawk's Avatar
cales98hawk is on a distinguished road
Originally Posted by Justin Kemp
The pipe should be painted / galvanized from inside to avoid rusting. But painting internally is difficult for long length pipes. Even galvanizing or any electochemical coating is not possible from inside. (I have not understood, why the pipe doesn't get plated from inside in any electrochemical process, where pipe is dipped completely in the respective liquid)
by my understanding the plating doesn't occur in inside the tube due to the magnetic field. I don't recall the details, but I know thats the cause.
I know that you have the same problem with peices that are v shaped or have a deep groove or valley. I have talked to the guys at the chrome shop a few times over the years.
Old Sep 11, 2010 | 12:01 PM
jaypo's Avatar
**UPDATE** Let my stupidity be your guide. Washed and started the hawk today. First time sense painting. Lets just say the paint didnt make it. Smoke and close to flames. So this week I'm taking it to be nitro plated. I'll post a follow up.
Old Sep 11, 2010 | 01:06 PM
Since the stock pipes wont rust anyway, that seems like a waste of money... Stick to "paint" or heatshielding paint instead...
Old Sep 15, 2010 | 11:20 AM
slapi01's Avatar
slapi01 is on a distinguished road
bummer the paint didn't hold up as they came out really nice... there is always JET-HOT coatings as they do inside and out.
Old Sep 22, 2010 | 06:50 AM
redmanmbz's Avatar
redmanmbz is on a distinguished road
I'm glad you updated the thread with the poor performance of the paint. I really like the look of the the black pipes, now I know I need to get mine ceramic or JET -HOT coated.
Old Sep 22, 2010 | 08:52 AM
Scumbag's Avatar
Scumbag is an unknown quantity at this point
I think it may all depend on the paint used. I have painted pipes on many bike and never had a result where I thought the pipe would burst into flames. I will say this though that the paint will smoke after the first start up but that goes away after a short jaunt up and down the road.
Also if you think the paint smokes, just try using header wrap and starting your bike with that on it for the first time.
Old Sep 27, 2010 | 07:47 PM
jaypo's Avatar
I get my pipes back from Nitro Plate in Nashville this week. I'll update pics.
http://nitroplate.com/ws/
Old Sep 27, 2010 | 08:13 PM
mboe794's Avatar
I've used Very High Temp paint in the past with reasonable results. Heat wasn't an issue. It was good for something like 1500 degrees constant and 2000 intermittent. Road debris takes a toll after a while though if used on bare metal. But I had great results using it as a sealer when my header was wrapped.
Old Sep 29, 2010 | 05:52 PM
jaypo's Avatar
Ceramic done
Got the pipes back from Nitro Plate today and they are now ceramic coated inside and out. Put them on and started it up. No problems. The coating cost $220 which was a bit more expensive since they stripped the chrome off chemically.
Pic with no belly fairing
All assembled
Old Sep 29, 2010 | 05:56 PM
RWhisen's Avatar
Those look REALLY nice! Can you tell any difference in the radiated heat?
Old Sep 29, 2010 | 07:14 PM
jaypo's Avatar
Not sure I ever paid too much attention to it before. I let it run for a while and I could see the heat radiating off the pipe but I won't know till I get more time in the saddle.
Old Sep 29, 2010 | 07:29 PM
RWhisen's Avatar
When are you going to change the CCTs?
Do you work for the postal service?
Old Sep 30, 2010 | 08:43 PM
jaypo's Avatar
Eventually
No but we take a lot of mail to the post office for my wife's job.
Old Sep 30, 2010 | 09:12 PM
RWhisen's Avatar
That explains the mail crates.
HU112BU
May 21, 2015 05:37 PM
Lonewolf
Apr 10, 2006 02:45 PM
CNI Dawg
Nov 3, 2005 09:12 PM
swordfish
Oct 14, 2005 07:20 PM
BooYeah
May 1, 2005 01:28 AM
