low mounts to high mounts
i am running wiley co. low mount pipes. Can conventional slip ons like mine be used with a modified midpipe and become highmounts???
if you can simply change and weld mid pipe what are the implications for the passenger pegs. |
Modified hangers and midpipes are the only difference, don't see why not...
The passenger pegs are rarely able to be mounted in stock position with highmounts... The prefered solution seems to be to use longer bolts with a small tube around them as spacers, and have them sit just outside the slipon... This is also what some of the manufacturers supply with their highmounts... |
