Integrated Tail Light Installation Help
Ok so I bought this tail light for my hawk and have a few questions... I know the plug on it goes into my factory brake bulb plug but as for the other 2 wires IDK??? I assume they go to the turn signals but do they go to the positive or negative? Any one ever hook one of these up before? http://i896.photobucket.com/albums/a...ps0c2660c3.jpg
Yes the turn signals have two wires.. 1: Ground 2: power wire. Your new tail light wires will be connected to the power wire for each turn signal. The question is, on your light.. is the yellow wire the right or left TS? and same for the blue wire? If no instructions came with it, trial and error till you figure it out.
Besides those two yellow & blue wires, is there no third wire for ground? If not, must be useing the ground at the brake light plug for the whole circuit board. |
(Post 354675)
Originally Posted by Northman69
(Post 354677)
ok so the yellow and blue wire coming from the light goes to my positives from my turn signal wires
(Post 354678)
From the one picture you posted, No light brand name, with no wiring diagrams available, no instructions to read and the light not in front of me, but across the country on your table............... YES:cool:
