SuperHawk Forum
-   Modifications - Cosmetic (https://www.superhawkforum.com/forums/modifications-cosmetic-34/)
-   -   help with flushmounts? (https://www.superhawkforum.com/forums/modifications-cosmetic-34/help-flushmounts-10501/)
azhawk1 Feb 7, 2007 09:00 AM
problems with the lp fronts they are the ones that are kind of triangular in shape .I really like the look so I will be bummed if they dont work. Every wire combo I try they blink fast I did a forum search but could not come up with enough info the wires from the signals are yellow and black no stripes. the package says blk=hot ,yell=grnd. any info would be great if not I guess thier going back.:(
marmaladedad Feb 7, 2007 09:09 AM
I traded mine in for a three-wire version. Any chance you can exchange them?
azhawk1 Feb 7, 2007 09:11 AM
possible?
azhawk1 Feb 7, 2007 09:24 AM
the guy at gdl cycles says that any aftermarket light blink fast unless you get the relay is that necessary ? any thoughts
tommygdbr Feb 7, 2007 09:26 AM
All flushmount/led turn sigs's will blink suped up honda civic fast unless a resister is installed, no????
I bought a model specific resister for my RR on Dennis Kirk a few years back. The led flush mount's went from super fast to regular speed............
NovaWildcat08 Feb 7, 2007 09:36 AM
Yes, the LEDs will blink faster without a resistor. You can find them on eBay.
Took me a bit to find them, but here they are.
http://cgi.ebay.com/ebaymotors/LED-T...mZ160066622579
marmaladedad Feb 7, 2007 09:37 AM
Right, putting in a resistor will slow the blink down. But LP (or other blinker sellers) have three-wire versions of their turn signals that don't have this problem.
azhawk1 Feb 7, 2007 11:14 AM
thanks guys I think Ill just let them blink a little faster as long as it wont hurt anything , Easier on the wallet:???:
cb21983 Feb 7, 2007 07:46 PM
I got a plug in replacement for the flasher relay. It was made by trickflasher and it has 6 different flash patterns. Pretty cool!!!! Only $20 on ebay if you look hard enough. Well worth it!! It even cures fast flash no matter what bulbs or leds you are using.
sprhawk neil Feb 8, 2007 03:38 PM
only led's should blink fast you did not mention if yours were led's? mine are lp's and blinked rapid when I hooked the wires up wrong have you tried to change the wires around?
azhawk1 Feb 8, 2007 06:17 PM
they are led in the front and then just put some bike masters on the back and all is good as far as I know will post pics soon thanks all.
