Gp shifting for cheap
Old Aug 25, 2010 | 09:47 AM
lukenukem47's Avatar
I bought a vfr shifter off ebay and it is a direct bolt up.. looking for a aluminum one next.. should shave little weight and when leaning in a hard left corner your able to shift with out thinking your going to loose a toe. It is a really clean look
Old Aug 25, 2010 | 10:59 AM
Jim TT's Avatar
Jim TT
I don't know that all VFR shift levers work but I do know that 3rd and 4th generation (1990 thru 1997) VFR parts work perfectly.
Old Aug 25, 2010 | 01:42 PM
comedo's Avatar
My comments from 2008:
JimTT suggested putting on a shift lever from a 94 VFR750 to reverse the shift pattern on a VTR. Thought I’d give it a try.
The short answer is that it fits and it works.
The tip of the gear change lever is tucked in about an inch from the stock position. Clearance between the gear change lever and the foot peg bracket is minimal. I was able to adjust the position of the lever so it doesn’t foul anything but others may not find the position to be acceptable. I think more pressure on the lever is needed to change gears but I didn’t do a back to back comparison. I’ve also got rather small feet, size 8 1/2. (shows what foot binding can do) People with bigger feet might have problems. The VFR lever is also ugly. Unlike the lovely cast piece on the stock VTR, the VFR lever is painted steel and it’s connected to the part that fits on the shifter shaft with a particularly hideous weld.
There wasn’t anything wrong with the stock shift arrangement on my VTR. There wasn’t a lot of play in it and, if I missed a shift, it was the rider’s fault rather than the machine’s. I find now that up shifts, especially first to second, are more positive because I’m pushing down on the shift lever. I haven’t missed a shift since I made the change but sometimes I do a flawless gear change to a gear I don’t want. The retraining process isn’t over. It’s amazing how much more attention I have to pay to push the lever in the right direction than I had to pay with the stock arrangement.
Old Aug 25, 2010 | 02:10 PM
RWhisen's Avatar
Former Superchicken Owner
No pictures?
Old Aug 25, 2010 | 09:59 PM
Vfr750 is what I used... got it off ebay for $15.00 here is the link
http://cgi.ebay.com/ebaymotors/ws/eB...m=360276820633
I am taking my original to a local weld shop along with this one as a prototype. I intend to incorporate some of the original parts, the objective is to make the whole thing out of aluminum.
Old Aug 26, 2010 | 06:42 AM
nothing's Avatar
ride it out
hmph I never thought about upshifting but in the downward lever motion seems interesting
Old Aug 26, 2010 | 07:35 AM
DocTremblay's Avatar
DocTremblay is on a distinguished road
Is the VFR lever necessary?
On my '98, I just flipped the lever over and shaved a little of the metal off for clearance.
Old Aug 26, 2010 | 08:39 AM
nothing's Avatar
ride it out
Why did you have to shave it... where wasn't it clearing?
Old Aug 26, 2010 | 11:34 AM
here is that pic of the prototype...
Old Aug 26, 2010 | 03:07 PM
434josh's Avatar
434josh is on a distinguished road
I like my alum one...
Old Aug 26, 2010 | 04:54 PM
what did that one come off of and what year
Old Aug 26, 2010 | 05:37 PM
mdbuehler's Avatar
mdbuehler
As in reverse shift? Word of advice (I ran that way for awhile) NEVER let a friend borrow your bike who isn't allready running inverted shifting as well no matter how well they understand its backwards. My poor Bandit died when a friend tried to go up a gear mid corner (luckily she was allright) but the bike did some very impressive summersaults through the infield
Old Aug 26, 2010 | 05:51 PM
434josh's Avatar
Honestly I do not know. I assumed it was a VFR shifter but only because I knew that was the most common mod. I have had it for about 3 years and it was that way when I bought it.
edit...
ebay is your friend...there are tons of different style levers on ebay but I don't know if the splines are fairly universal.
http://cgi.ebay.com/ebaymotors/CRF45...Q5fAccessories
Old Aug 26, 2010 | 07:24 PM
mboe794's Avatar
Now you guys just need to add an ignition interrupter quick shift to that lever!
Someday, when I have a job again (hopefully soon) I will attempt this. At first I wasn't thinking about reversing the pattern. But now that I see how easy it is, I just might.
The only thing is that I ride a few different bikes regularly. I don't know if I could readjust every time I hop on the SuperHawk, even if it does become a track only bike.
Old Aug 26, 2010 | 07:44 PM
434josh's Avatar
I have ridden a few other std pattern bikes with no problems. The GP style just seems more natural to me anyway.
Old Aug 26, 2010 | 07:49 PM
434josh's Avatar
Ok, a little research and I found it.
1999 VFR 800.
http://www.sportbikeroads.com/vfr800.htm
look at photo 42
Old Aug 26, 2010 | 08:55 PM
autoteach's Avatar
cant you just flip the tranny lever on ours and achieve the same result?
Hawkrider
Apr 11, 2013 04:52 PM
davidhartley
Jun 29, 2007 12:14 AM
timc
Apr 28, 2007 09:30 AM
The Hawk Guy
May 2, 2006 04:55 PM
apbrian112
Sep 28, 2005 12:30 PM
