Cutting fairings?
Did a little searching with not much luck. Anyone know if a thread for the proper way to cut on stock fairings without busting them up? Thanks guys.
If I was to cut fairing panels I'd use an air saw, with where I wanted cutting marked up on masking tape - There was a chap with a red storm that had trimmed his into a half-fairing, you could pm him.
http://i692.photobucket.com/albums/v...446/598446.jpg |
i used a dremel with a cutting wheel and masking tape and a little patience.
dremel. the plastic is not brittle, so you should be fine.
Thanks for the tips guys. If I finally make up my mind on cutting i'll post some pics.
| All times are GMT -7. The time now is 11:31 PM. |
