What material are the stock fairing made of
Guni was trying to repair a set and was told you can solve ABS plastic in ethyl methel either to make a glue, but I cut up a piece of the fender and it did not solve. Then I made he glue using some Legos which I know are ABS and it did not bond well to the bare fairing material.
That said how sure are you that the black plastic of these hawk fairings are ABS.
But check for your self
http://www.boedeker.com/bpi-burn.pdf
This is ABS
There are some great products for gluing abs but it is a thermoplastic which means you can weld it. It can become molten without losing its properties.
Use a soldering iron (carefully don't burn it) and you can rebuild the whole piece.
Mcmaster-carr.com sells abs welding rod cheap.
I've dabbled in plastic welding with a soldiering iron and filler rod.
But once i got a real plastic welder, it became much more efficient and effective..
One of the gold standards in plastic welding tools
https://www.interstateplastics.com/L...FQcDaQodcMQDpQ
But cheaper versions are available
Hot Air Welders for TPO or PVC, Membrane Welders, Bak, Laron, Rion
I bought this one
http://www.bestmaterials.com/detail.aspx?ID=16011
And this
http://www.bestmaterials.com/detail.aspx?ID=16431
and this
http://www.bestmaterials.com/detail.aspx?ID=17583
There are other way cheaper version as well..that Im sure will work when received, how long, how well and if replacement parts / service capability is available is another story.
http://www.ebay.com/itm/1600W-Hot-Ai...3D282213136912
http://www.ebay.com/itm/WELDY-1600W-...3D322119585717
I bought this one
And this
and this
IPS Corp. makes 3 ABS cohesive solvents for "welding"; i.e., Weldon 2354 "Clear, water thin, fast curing solvent cement for joining ABS". It does work on the VTR fairings and will also "gel" ABS shavings and rod into a filler. Be sure to drill tiny holes at the end of cracks to minimize crack attenuation.
Harbor Freight plastic welders. I had one no longer sold which burned up the second time used.
Plastic Welding Equipment and Plastic Welders at Harbor Freight
Thanks everyone. I wound up welding them together. I just a regular $10 soddering iron. I took some extra time to melt and drag some material in from the edges. I cut up a scrap of the fender and used it as filler rod.
I'm positive these are stock fairing just was unclear why they don't dissolve in the ethyl methyl ether..
uchi
09-30-2010 05:08 PM
