Best LED Turn Signals for Superhawk
I'm looking for bright LED turn signals F&R (non-flush mount variety) for my Superhawk. Any recommendations? I'd like them to be fairly easy to install (plug and play) if possible.
Also, should a go with a resister or a flasher relay? Thanks for the help! :) |
Go with the LED flasher relay, simple plug and play.
They are everywhere on EBay. |
What about the turn signals themselves, any recommendations for some bright ones that will fit the Superhawk?
This electronic flasher relay from superbrightleds.com has been recommended on here in the past for use with LED signals.
part# = LF1-S-FLAT Haven't used it myself. |
I use Protons front, has both running and turn signals. Order the ones for the RC51. Rizoma Zero Rears, with the LED relay listed above. No resisters needed with that.
If your energetic, go for the haknslash LED taillight mod, its nice too. |
Thanks for the recommendations!
I actually did the LED mod from Haknslash, it is awesome! |
i have protons installed on mine, got them for the run feature and the strobe turn signals. can't report on them yet, as i have the fairing off to install them. I had to use hot glue to install mine, as I couldn't find any rubber grommet to fill the "gap" left from the different size.
Check the show me your lights sticky @ the top of this section.
