My work in progress
3 Attachment(s)
Still waiting on the right exhaust can (damaged in shipping). I better get the paint done, 'cause it's about time to ride!
Re: My work in progress
2 Attachment(s)
A couple more...
Tres cool!
i like the steering stabilizer was it meant to mount there or was it your idea
It started with a damper and a fork tube clamp from a GSXR. I made the mounting bracket that attaches to the lower instrument bracket mounting hole. It just clears the fairing on the inside.
Hi!
Tell about those forks and what did you had to do to get them fitted!!! And which brand are those rearsets? -Janne (VTR1000F '98 & RG250W '84) |
3 Attachment(s)
Ready to roll!!!
1 Attachment(s)
One more...
I picture subtle black tiger stripes on it :P
Ya, what front end is that? The exhaust looks awesome too. Can you fit the passenger pegs? |
It's an RC51 front end. Moriwaki exhaust. I haven't figured out passenger pegs. I thought I might try CBR929 pegs.
I can hardly believe she's mine! |
I totally agree, this is too cool! What a set of pipe and what a nice front suspension :shock: Even that I'm totally jalous :oops:
I have soooo many questions, but one at a time ( as maybe you know, i'm in preparation to also mods my front end with a 1000rr one) So, is the stock top fairing have fit without any cut? As I know the RC front suspension ( as weel as the 929/954 or 1000RR ones) are much wider than the stock VTR? What a great work again, congratulations!! |
I've never really like blue for bikes but boy that sure looks good with those Ti pipes. Even the frame spars appear to have a blue tint now!
Umm, is that rear tire on backwards? |
What rear shock have you got fitted?
Fairing requires some trimming for sure, the forks barely fit.
I won't even answer Doug's silly tire question! :roll: Just kidding! When I saw the color (Honda Aegean Blue) I had to do it. Fox Twin Clicker rear shock (no longer available, apparently). |
Wow, those pipes really work with the color scheme. Good job!
Thats awesome! Very nice work!
thanks for all the positive feedback!
I'm taking her to Thunderhill raceway next Friday for a good thrashing! (she loves it when I'm rough with her) :twisted: |
It's time for another question 8)
On the previous episode of the RC996 mods :D , we have learn that in order to fit at 43mm front end suspension on a VTR, we need to perform some cutting of the top fairing. Now, I ( and maybe also "we" I guess ) would like to see more pictures of this cutting! and also to know if there is some clearance problem with the radiator and/or the oil coolant radiator due to the greater width of the 43mm fork :?: Thank you so much RC996 you are like a pioneer, you have make the way for those who aspire to a better VTR, AKA SH or FS :D |
I just put the fairing up and marked where it started to interfere (after the forks were mounted). I freehanded an arc, then tried it and finally got it all to clear. Not a big deal, but several iterations to get it right without going too far. the lower triple clamp causes the biggest clearance issue with the fairing.
Turning radius is slightly impaired by the upper coolant hose. Only an issue when you're rolling it around the garage and making tight turnarounds. |
Originally Posted by rc996";p="
(Post 5827)
Yep, that's sweet. The blue has a unique sheen to it. Is that just the photo?
How has the handling changed with the new forks? |
Originally Posted by gadget";p="
(Post 8321)
(Post 8321)
Aside from modifying the fairing for the wider fork, did the RC51 triple clamps fit the Hawk's stearing head, bearings, etc?
The head bearings are almost the same. I say that because the VTR bearings work with the RC51 inner races, but the RC51 bearings don't work with the VTR outer races. So there is some incompatibility there. I didn't measure anything to figure out what was different. I ran it with the VTR bearings for a while, then changed to tapered roller bearings. I bought tapered rollers for the RC51 and they are perfect.
Other than that, head tube length is the same. RC51 triple clamp offset is 5mm less than the VTR. I lengthened the shock 5mm, which is about 30mm at the rear axle. This steepens the head angle. Less offset gives more trail. The combination works very well. With stock rear shock length the trail will be excessive with the RC51 triples (probably 929/954 triple clamps as well). |
Wow, sounds like you learned a lot doing this project. I'm surprised that the rc51's triple clamps have less offset, and therefore more trail. I guess that the steering head is at a different angle.
Your tenacious work on the project is impressive. That's a lot of adjusting, reconfiguring. Had you heard that the rc's front end would fit, or did you just go for it? In any case, it's cool. |
Actually, I had people tell me they wouldn't fit. I was parked next to my friend's RC51 and noticed that the tops of the forks were in the same position. We measured them and found them to be the same length.
The RC51 has a steeper head angle than the VTR, which requires less offset for a given amount of trail. Head angle and trail work together to determine steering response and stability. Some people make radical changes to steering geometry by raising the forks, etc. I like to be a little more conservative, trading some steering effort for stability. |
Yeah, I understand the trail/rake dynamic, though I haven't played with it the way you have.
Interesting that the tapered bearings for the RC fit while the roller bearings don't. Were you able to measure before purchasing them? It would be a drag to spend the $50 only to find that they wouldn't work. How much was the RC front end? I assume you were able to get a complete one, with brakes and everything. |
I measured the head tube beforehand to be sure the outer races would fit.
Mostly, I just dug in and tried stuff, with some input from a racer/builder friend (who told me the forks wouldn't work). I bought the forks/axles on ebay, traded some work for a new RC51 wheel, bought 929 brakes, master cylinder and RC51 rotors on ebay, got the 929 clip-ons free. I thought the clip-ons were temporary to get me running, but I like the riding position, so I've just stayed with them. I sold my forks with stock springs, front wheel, brakes, Racetech springs and fork brace on ebay. Ended up spending about $250 net for the conversion. |
Excellent!
Thanks for the details. If you don't mind, why the 929 brakes instead of the RC's? Are they that much better? I wonder if Gxxr brakes, or R1 brakes, would fit? |
I was looking for brakes, knowing the 929 calipers were the same. I saw some and bought 'em. 8)
