SuperHawk Forum
-   Members Rides (https://www.superhawkforum.com/forums/members-rides-35/)
-   -   Bike is ready to ride (https://www.superhawkforum.com/forums/members-rides-35/bike-ready-ride-34511/)
2wheel May 7, 2017 10:56 PM
6 Attachment(s)
Hello a few months ago began my journey here and with my new bike. When I was thinking of getting it I asked here for advice and ultimately decided to buy a 2003 wrecked Superhawk for a grand. It had also been left outside for over a year without a cover. it started and ran and the engine and gears seemed strong. After delving into it I discovered two things. There was a fairing stay that had broken off and left a hole in the frame. Also the bike needed ALOT of little things. Here is a list of all the things I have done so far.
-both fork seals and new fork oil.
-plugs
-cam clearance and timing
-Manual CCT, Had to do the timing because my cam chain slipped.
-new grips, throttle sleeve, mirrors, brake lever was bent.
-Changed out the headlight
-changed the R/R for a mosfet from a CBR1000
-changed out the integrated blinker tail light because it didnt integrate no more.
-changed out the thermostat and temp sensor (gauge still doesnt work on the dash, although I did ground the gauge for a second and it does work)
-Cleaned the carbs, put some easy access vacuum hoses for carb balancing, didn't even need to balance the carbs.
-trimmed the tail area
-re routed the seat release, you dont have to use the key there is a small pull lever underneath the seat now. My key was getting bent.
-Minor body work, the tank dent got bondoed and painted but I used a different shade, gotta fix tat.
-cleaned chain, still good.
-new fluids.
-cleaned a little rust
-needs brakes and a few other small things
The thing runs good now and I wanted to thank you all for your help. I havent decided what to do about the hole in the front but I cant really sell it without taking a huge loss or spend $300-$900 swapping the frame or finding a welder. Im gonna ride it for now. It has been an adventure and I couldn't not have done it without referencing this forum, so much good info here. Thanks!
I did this as cheaply as possible, I still spent around 500 bucks to get it to this state. By no means a show bike, just an every day ride!
My bike as it sits
Attachment 21230
Attachment 21231
Attachment 21232
Attachment 21233
Attachment 21234
Before I bought it
Attachment 21235
kenmoore May 8, 2017 01:24 AM
Well done mate,
Now get out and enjoy it.
Wolverine May 8, 2017 05:27 AM
Agree! Nice job, now get to know the bike and you won't be thinking of resell issues. They are very reliable machines when taken care of.
Fastguy59 May 8, 2017 11:03 AM
Well done. If you can fine someone with a twisted frame to can cut out the part that broken on yours then you just need a talented welder to tig it back in place. Mind you the steering head bearings will then need to be changed. For now I recommend some gaff or duct tape and cover the hole as the back side of the bearing are susceptible to dirt entering through the opening...
2wheel May 8, 2017 07:01 PM
:rolleyes:
This bike is great, I love it. The torque is so nice for city riding and that's the majority of my riding. I love this bike!! The clip ons are too low for my liking though. The handling is great and it so skinny! My first bike was a Suzuki VX800 and that was a great albeit underpowered bike but I loved the low end and skinniness. The superhawk is like it's big better looking brother. My previous bike was a FZ1 and while it handled ok and the top end was screaming I just appreciate the superhawk so much more. I have found a bike that I want to keep for a long time.
2wheel May 8, 2017 07:02 PM
Hey thanks for the tips, I will be in the lookout for a twisted frame. This seems like the way to go.
xeris May 8, 2017 08:57 PM
Hmmm. Apparently the hole left by crashing the faring stay is somewhat common. I would not have thought that.
https://www.superhawkforum.com/forum...sh-lever-5145/
2wheel May 8, 2017 11:01 PM
When I first discovered this a day after I brought the bike home I was absolutely crushed, a hole in the frame! I thought I was done but it is a common thing and everyone told me that it's not that bad, to ride it and it would be fine. I am probably going to get it welded at some point but it isn't the absolute disaster that I thought it was.
ae29 May 10, 2017 03:09 AM
i reckon hard putty and spray paint would conceal that hole
