SuperHawk Forum
-   Knowledge Base (https://www.superhawkforum.com/forums/knowledge-base-40/)
-   -   Stator issue??? (https://www.superhawkforum.com/forums/knowledge-base-40/stator-issue-36178/)
Kwikkawi84 Mar 2, 2024 09:32 AM
Stator issue???
So I've tested from leg to leg and I get a reading of 0 ohms all the way across and I'm not seeing a short to ground on any legs but what should my voltage output be??? My bike is getting no voltage back to the battery it seems
ascothawk Mar 2, 2024 10:53 AM
Voltage from the rectifier is AC voltage,it is converted to DC by the regulator/rectifier. Under the seat in front of the battery box there is a plug connector where the stator wire connects to the wire harness,mine had melted. I repaired this and that fixed my charging issues.
xeris Mar 4, 2024 06:44 AM
At what point are you taking the readings? The connector that ascothawk is referring to is where the test should be performed. No continuity to ground and .2-.5 ohms between the three wires.
https://cimg9.ibsrv.net/gimg/www.sup...9c46e40c07.png
