Slow flow jet clogged
Old Dec 13, 2025 | 10:19 AM
Oldrider78's Avatar
Oldrider78 is on a distinguished road
Just pulled the carbs on my 1999 Superhawk for cleaning. The previous owner has upgraded fast flow jets, but left the slow flow alone. After an hour in the ultrasonic cleaner, I checked the slow flow jet and found that I couldn't see down through the jet I tried to push a cleaning brush through jet from top to bottom, but couldn't. The four holes in the bottom part of the jet are clean and cleared up nicely. But, I can't see daylight down through the jet. How do you all get the jet cleaned out?
Old Dec 14, 2025 | 04:40 PM
Oldrider78's Avatar
Update: I watched a YouTube video that showed one guy using a butane torch to literally melt the varnish, then push in a very thin wire strand. I used a sewing needle to get a tiny opening started, then tossed it into some Evapo Rust.
Old Dec 20, 2025 | 02:48 PM
I haven't had to in a long time, but I use a micro drill bit. Usually just pick one that I know is smaller than the hole and push it through then make sure the debris is gone.
3amta3
Jun 22, 2011 11:19 AM
franz125
Sep 16, 2010 01:13 AM
Jens_denmark
Jun 22, 2010 11:50 PM
jtgraha2
Jan 20, 2008 08:54 AM
clogee
Sep 28, 2006 09:37 AM
