Shorter shifting 'Hawk
Old 12-19-2006, 05:59 PM
For those of you wanting to get better shifting with shorter throws, try the following:
* Loosen the adjusters on the link and extend it out about 4-5 threads. This will move the shifter in the downward direction. Leave it loose.
* Now loosen and remove the shifter arm bolt and remove and replace the arm exactly ONE spline in the clockwise direction. Install and tighten the shifter arm bolt.
* Adjust the shift lever to your liking and tighten the two locknuts.
What this does is gives you less lever travel due to the increased angle of the shifter arm. It works great at the track and street with or without the clutch.
Hawkrider is offline
Old 12-20-2006, 03:33 AM
shayne's Avatar
Man, I have had a couple of arguments about this!!
Non-believers telling me it can't work. It is hard to explain, until you see it work on a bike. My physics is not what it used to be. LOL
shayne is offline
Old 12-20-2006, 08:18 AM
RCVTR's Avatar
I've spent the time at track days to get that adjustment right and it makes a huge difference.
RCVTR is offline
Old 12-20-2006, 08:29 AM
Thanks for the info. I am looking forward to trying it (although it will have to wait until Spring).
cheers
mikstr is offline
Old 12-21-2006, 07:15 PM
shayne's Avatar
cheers
My tip here would be to install heim joints on the end of your shift rod while you are at it. The ball and cup joints that Honda use have a fair bit of play in them even from new. A heim joint like Yamaha use on the R1 is a LOT better. Your local engineering supply shop should be able to supply them with left & right hand threads. I can buy a pair of them here for $40 so should be even a bit cheaper for you. A pair of genuine Yamaha dust boots finishes it off nicely.
Tip no. 2 is to re-bush the pivot for the shifter. Lots of slop in there you can take out too.
I thought these bits on my bike were worn out when I got it, so I went to Honda and looked at a new bike and it was the same! Just cheap components. I am used to dirt bikes that have no likages at all, so it felt terrible to me.
These mods sort it out nicely and are cheap to do.
shayne is offline
Old 02-07-2007, 06:36 PM
Birdoprey's Avatar
Bump!
makes sense. less rod movement but less leverage so a slight amount more effort, probably won't notice it.
just did it. will try it out tomorrow.
Birdoprey is offline
Old 02-07-2007, 06:40 PM
tommygdbr's Avatar
tommygdbr is on a distinguished road
Sounds like a new project for me. Thx for the info, I will do it tomorrow
tommygdbr is offline
Old 02-07-2007, 07:37 PM
I did this mod while I was going through my bike. It looks like it will do a better job of clearing the toes of my riding boots. I always feel like such a duck with my toes stuck out instead of tucked in on the pegs.
nuhawk is offline
Old 02-08-2007, 11:19 AM
J.J.'s Avatar
J.J. is on a distinguished road
Sorry, I'm probably an idiot, but what do you mean when you say "loosen the adjusters on the link"? What link?
J.J. is offline
Old 02-08-2007, 02:55 PM
It's actually the adjustable shifting rod. It connects the shift lever to the arm attached to the shift shaft. There's (2) 10mm lock nuts on there. Loosen them and then turn the rod to adjust.
Old 02-08-2007, 07:17 PM
It doesn't take much. My adjustment was about 1/8th inch total.
nuhawk is offline
Old 02-08-2007, 07:39 PM
Thumper's Avatar
Works great, did it years ago after reading a post on RLZ.
To add on e more tip, you can also improve the shifting even more by adding the FactoryPro Shift Detent kits. Really makes the gears pop solid when shifting. The shift detent are is a piece of crap on the stock setip compared the the FactoryPro Roller bearing Shift Detent Arm.
Sorry, no pics of the stock and FactoryPro arms, did this mod four or five years ago.
Thumper is offline
Old 02-13-2007, 12:08 PM
kevink2's Avatar
kevink2 is on a distinguished road
Works great... fantastic tip.
kevink2 is offline
Old 11-29-2007, 12:37 AM
jameszr7s's Avatar
jameszr7s is on a distinguished road
anybody know if you can buy a shorter linkage to shorten the throw more, maybe from a sportyer honda
jameszr7s is offline
Old 11-29-2007, 04:57 AM
Most likely not, the shortening of the actual linkage here is a matter of a few mm's only... The main purpose isn't making the link shorter, it's changing the angle, wich changes the precision of the lever...
A better idea is as shayne suggested, I have tried it...
Tighten up the original lever with a shim on the lever axle to remove play, and possibly give it a new bushing if needed, then use heim joints...
Tweety is offline
Old 11-29-2007, 06:52 PM
How did you attach the new heim to the shift lever (the OEM is riveted)? I already lenghtened my lever for mty Vario adjustable pegs & did the linkage "adjustment". Real thin shim stock is required instead of re-bushing the lever pivot.
skokievtr is offline
Old 12-20-2007, 03:55 AM
How did you attach the new heim to the shift lever (the OEM is riveted)? I already lengthened my lever for mty Vario adjustable pegs & did the linkage "adjustment". Real thin shim stock is required instead of re-bushing the lever pivot.
I used a Stainless steel socked head hex fastener, nut and some high strength thread locker (Loctite 271)
Tightened things down adding a touch of thread locker to the nut. Ground the head off the fastener, and all excess off after the nut. Great fit, will never come loose. And if I ever want to replace a part of the system, it's as easy as replacing the fastener. ($0.35)
E.Marquez is offline
Old 09-12-2008, 12:59 PM
finepooch's Avatar
i've been doing this to all my bikes for years. i usually change it by two splines. the throw isn't being shortened, just moved. it feels better because your upshifts are much more "sure".
i've never figured out why the bike manus put the levers so high. it's rediculous.
finepooch is offline
Old 09-12-2008, 01:51 PM
CentralCoaster's Avatar
Makes sense to me! I may give it a shot. It's so easy to shift anyways clutchless, a little more effort might be better.
CentralCoaster is offline
Old 09-20-2008, 09:29 PM
Woodytick's Avatar
Woodytick is on a distinguished road
do all that but make the gears backwards. to where you are shifting down to grab a higher gear instead of pulling up. it makes it a hell of alot better. this is how my race bike is set up. i just think it is easier to tap down then pulling it up. just my 2 cents anyways...
Woodytick is offline
Old 10-11-2009, 09:56 AM
Superclean09's Avatar
Superclean09 is on a distinguished road
My SH is the worst shifting bike 1st to 2nd gear that I have ever had. My CBR954RR was almost as bad but I found that pre-loading the shifter before the shift let it shift smoothly without any mods. I will do the mod in Spring but there is still a few weeks of nice riding weather here in Victoria. Sunny and 13 degrees right now!
Superclean09 is offline
Old 11-06-2009, 03:56 AM
Its A fire, Its A Storm!
Storm's Avatar
Storm is on a distinguished road
Just did the mod now... I will ride Tomorrow and report back. Seems better just by a small test in the shed but the road will be the real test i guess Cheers, T
Storm is offline
Old 11-06-2009, 04:23 PM
Storm's Avatar
Ok Adjusted the arm 1 turn clockwise and went for a test ride... Came back and did an adjustment on the rod to suit my Foot/boot and it is GREAT, very happy!! Cheers for the tip, Tony
Storm is offline
Old 11-06-2009, 09:30 PM
Who are you?
Just_Nick's Avatar
Did the mod too, using my method *cough*, and it does seem to be a little better.
Just a tip, the throw is indeed shorter, however you need more force to make up for that. If you don't upshift hard enough, it will simply pop out of gear.
Just_Nick is offline
Old 04-21-2011, 03:42 AM
boxs21's Avatar
boxs21 is on a distinguished road
look like good setup, I should try it
boxs21 is offline
Old 12-23-2011, 07:55 PM
New Hawk Rider
eersfanpilot's Avatar
eersfanpilot is on a distinguished road
Did this on two SH's today and I must admit, noticeably different. It feels Great! Thanks Hawkrider! Also, for somereason I can't access your 996 site on my tablet or phone, any advice? I like to use the tab in the garage while working for instructions and pic reference.
eersfanpilot is offline
Old 03-26-2012, 09:59 AM
Another OCMD victim...
Firestorm996's Avatar
Did the mod last weekend, what a difference!!!
Thank you Greg, valuable info as always.....
Firestorm996 is offline
Old 08-25-2012, 12:48 PM
twist's Avatar
I have a 2002 VTR. shifter rod is simply a threaded rod with both ends threaded, (cant adjust w/o removing shift lever). Is it 4-5 threads on each end? I got the rest.
twist is offline
Old 08-25-2012, 01:39 PM
Yes, you can adjust it without removing the shifter... You loosen the locknuts, and then spin the threaded rod... That makes it longer... So yeah, 4-5 goes for both ends, as both spin together... the whole point of it is to be able to adjust the shifter position...
Then you move the splined arm, and set the pedal to where you want it, and lock it...
Tweety is offline
Old 08-25-2012, 04:11 PM
twist's Avatar
thanks! Gonna give it a try.
twist is offline
Quick Reply: Shorter shifting 'Hawk
