Running EU bike with ICU from US bike
Does anyone have a picture of the ICU wiring harness connector from a USA spec. bike clearly showing the pin-out and cable colours?
I would like to use a USA spec Ignition Control Unit on a EU spec. bike, so I need to confirm that the pin-out is the same or not. |
What year bike as there are 2 different plugs
Hello.
The workshop manual is really not answering the pinout...neither are the schemas that I've seen around the internet. So, please could someone post a pictures of 2001 --> later Superhawk ICU connector showing which wire goes to which pin in the socket... I'm working on 2002 Firestorm which I purchased from an insurance company. This bike had HISS version ICU. I could not get the ICU responding so I bought from ebay an US-version (same year) ICU. With the US-version ICU I cannot get a spark. I've checked all the obvious and searched the web sites still no spark. I hooked USB-scope and could see the pulse generator is sparking fine and the power (Black/white) voltage is not dropping dramatically (Below 11,5 Volts) during starting so there should be spark. Today I accidently got spark when I connected my finger to the HISS receiver RxDT line. The spark was like the pace of my heart rate ... really ! So from that I started thingking maybe there is difference in the US vs EU ICU pinouts. In the schemas it looks the connections are identical (except for the HISS receiver) but are wires really going to the same physical pins...? So, please post pics... Best Regards Mikko |
You might be better off going to vtr1000.org for your questions. Since this is a U.S. site, they will have what you need.
Well, excuse me...
I understand this is US site. That's exactly why I posted this question here. I thought there is more chance of getting info about US version ICU connectors in US forum than in EU forum... Regards. |
Originally Posted by MYle
(Post 387963)
Well, excuse me...
(Post 387963)
Well, excuse me...
I understand this is US site. That's exactly why I posted this question here. I thought there is more chance of getting info about US version ICU connectors in US forum than in EU forum... Regards. No bike in this country has that system so no one here has seen one. The reason for the referral to the UK site is that they have experience with that system. Hope you get it all sorted. |
Hello Gents.
Sorry, Maybe I was a little too hasty... Anyhow. I know you don't have that *X#%!!:n HISS hence I'm asking. If just could get a decent picture of the US ICU socket where the wires can be seen I think it would be very beneficial for lots of people. Not only for me. I've been searching in the web but so far haven't found a decent pic or details of the US ICU socket. Cheers mates. Mikko |
Originally Posted by 8541Hawk
(Post 387978)
No one was trying to be rude to you. You might not know it but the HISS system was never released in the US.
I have an extra wire harness and took a couple pictures. I think the harness is from a '98. Hope this helps as well.
I'm actually glad I took these pictures. When I blew them up, I noticed a gash in one of the wires! http://i1218.photobucket.com/albums/...701_154421.jpg http://i1218.photobucket.com/albums/...701_154357.jpg |
Thanks Grux.
This is just what I was looking after... Except for the 2001 and newr bikes. They have different socket: http://aijaa.com/0vGywq Right side http://aijaa.com/b4iO9H Left side I made a project thread of my bike to the vtr1000.org if want to have a look... www.vtr1000.org ? View topic - Flying Finn (still without wings...) Cheers Mikko |
2 Attachment(s)
I have an '02. I'll try to post a couple pics for you tonight.
OK Here are pics of each side of the connector. Hope this helps. |
CrankenFine, You might have saved a day (or two... ).
Thank's a lot. Very good photos. If this don't help then at least it is not because of lack of support from you guys! At the first look there is differencies in the wiring. I'll make more thorough investigation on this in the weekend. Have a nice weekend. Cheers Mikko |
Hello!
The bike is running now with US-NON-HISS ICU. There was one (yellow) pulse generator wire in different pin in my (EURO-socket) bike. Once I changed that got good spark and got the engine running. So, CrankenFine, Thank you very much for your effort. The pics you send were really the key to solve this issue. Have a nice week. Cheers Mikko |
Glad it worked out.
Guess this means we could add HISS to US bikes if desired? |
You could, but it is more complicated than removing the HISS.
You would need to have: 1. HISS-ICU + at least one key programmed to that specific ICU 2. HISS receiver. This comes around the ignition switch to recognize the correct key (Or the ID chip in the key...) 3. Wiring for the HISS receiver. 4 wires for the receiver+one for the indicator (These wires, I don't know if they are in US wiring harness) 4. HISS indigator. Also don't know if this is in US instrument panel. (BTW the US-version ICU still blinks the HISS indicator when turned of...) 5. Change wiring in the socket for the HISS ICU Otherwise this modification is quite straightforward and could be done in one day. There's a map I made of both of the ICU sockets to help to see which pin goes to which pin. Can be downloaded from here: Euro & US ICU socket pins Cheers Mikko |
(Post 388191)
Glad it worked out.
Guess this means we could add HISS to US bikes if desired? I have four of them I could send you... All complete, and all in perfectly working order, as they are absolutely theft proof and will not let you start the bike no matter what you do to them, working and correct key or not... Bloody nuisance is what they are... |
