Everything but ignition and start.
Old 04-12-2015, 04:24 PM
ryan.neumantruckservice's Avatar
ryan.neumantruckservice is on a distinguished road
Ok, so I took the battery out Over winter. Put it back in fully charged.
Push starter button and nothing. With key on I do not have 12 volts to coils. I jumped the black wire w/red stripe to yellow wire w/ red stripe at the harness going to the switch and it turns over.
I had years ago disabled the clutch wire. And I have verified kickstand switch is working also neutral safety is working correctly too. Where am I going wrong?
ryan.neumantruckservice is offline
Old 04-12-2015, 04:25 PM
thedeatons's Avatar
Is the Off/Run switch on the right handlebar in the Run position?
James
thedeatons is offline
Old 04-13-2015, 01:45 PM
CrankenFine's Avatar
Headlight fuse OK? US version won't run without good headlight fuse in place.
CrankenFine is offline
j shizzy wizzy
06-28-2009 04:32 PM
oicdn
09-07-2008 06:47 AM
spencerlvevacque
04-20-2008 04:54 PM
Hawkrider
Forum Feedback
03-01-2007 03:41 PM
igeorgei
10-02-2005 08:56 PM
Quick Reply: Everything but ignition and start.
