SuperHawk Forum
-   Knowledge Base (https://www.superhawkforum.com/forums/knowledge-base-40/)
-   -   Rear wheel spacer fit (https://www.superhawkforum.com/forums/knowledge-base-40/rear-wheel-spacer-fit-27669/)
Quin Feb 27, 2012 08:48 AM
Hi. I've just got a quick question regarding how the rear wheel spacer fits. I've had the wheels apart for about 4 months cause of the build I'm doing and can't remember how much movement the spacer in the wheel should have. I replaced all the bearings and am pretty sure I installed the bearings all the way but I seem to have approx 1/16 of play. Does this seem right?
Wicky Feb 27, 2012 09:13 AM
Shouldn't be that play once all torqued up
Check diagram that all parts in place and in correct order
Ronayers.com Microfiche Honda>Motorcycle>1999>VTR1000F>REAR WHEEL
And check the downloadable PDF service manual for nut torque etc
Quin Feb 27, 2012 11:30 AM
It should all be in place as I was all over bike bandit for that very reason lol.
Quin Feb 27, 2012 07:43 PM
Do I brought the wheel to my work and put it in the press. One beating just needed to go a you know what more. Thanks for the info.
