SuperHawk Forum
-   Knowledge Base (https://www.superhawkforum.com/forums/knowledge-base-40/)
-   -   Poll: What fuel do you run in your Superhawk? (https://www.superhawkforum.com/forums/knowledge-base-40/poll-what-fuel-do-you-run-your-superhawk-19863/)
Just_Nick Aug 12, 2009 03:36 PM
So I'm curious to know what you guys run in your SuperChickens. So let's see what people run.
Edit: It appears what is posted under the seat is 91 RON, which is equivalent to 87 grade here in the US.
jbaxx Aug 12, 2009 04:04 PM
87
REDVTR1000 Aug 12, 2009 04:06 PM
i used to be all "91 or 93 if you got it" and then i did some reading. there is no real gains to be had with a higher octane on our motor due to the very low compression. 87 is the shit. stop wasting money on the other stuff
drew_c14 Aug 12, 2009 04:08 PM
87
Just_Nick Aug 12, 2009 04:18 PM
Oh, and I ran two tanks of 87, getting 41mpg on both, and I am now going to try 91 out.
We'll see. I kinda felt like I was getting a smoother idle with the 91.
LineArrayNut Aug 12, 2009 05:20 PM
the whole thing...
Originally Posted by Just_Nick (Post 230994)
So I'm curious to know what you guys run in your SuperChickens. I know it says minimum 91 under the seat, but I know not everyone can read/likes following directions. So let's see what people run.
It doesn't just say 91; its 91 RON min. Makes a difference here in the US.
http://en.wikipedia.org/wiki/Octane_rating
87 is sufficient here in the US as a R+M/2; but since I often lug the beast, I run 89. Whatever. It's like oil. Or tires.
Hotbrakes Aug 12, 2009 05:25 PM
Yeah, we recently discussed this in depth here. Tried and proven in 3 local 'Hawks including my own that 87 gets the best mileage and runs just as well as the other stuff.
Pimpsterbim1 Aug 12, 2009 06:18 PM
I run premium (92 or 93 here in NW Ohio).. Its only 20 cents more a gallon compared to 87.. Plus my car "requires" premium, so I just run it in both.
timdske Aug 12, 2009 06:36 PM
I run 89. I haven't seen any gains with 93.
CentralCoaster Aug 12, 2009 07:01 PM
91 RON (Europe) = 87 octane (US)
Makes perfect sense. Riding my 'hawk requires me to wear a helmet, so I just wear it while driving my car too.
RK1 Aug 12, 2009 08:38 PM
1 Attachment(s)
oh boy
autoteach Aug 12, 2009 08:48 PM
My car runs diesel...
Anywho, don't lug the beast, let her breathe. Run it above 4k rpms and you might see better fuel mileage. Anything over 5 is diminishing returns. My buddy noticed it with his sv650 as well.
Syclone Aug 12, 2009 08:59 PM
Originally Posted by RK1 (Post 231026)
oh boy
No shit, how many stupid fuel and oil threads do we need.
VTRsurfer Aug 12, 2009 09:09 PM
:popcorn:
inderocker Aug 12, 2009 09:43 PM
1 Attachment(s)
I run VP race fuel with two bottles of octane booster per liter... nothing but the best for my baby. :p
https://www.superhawkforum.com/forum...8&d=1250138837
killer5280 Aug 12, 2009 09:46 PM
I run 93 octane only because I have high compression pistons and she won't run good with lower octane. Before I installed them I ran 87 with no ill effects.
FL02SupaHawk996 Aug 13, 2009 06:33 AM
93 when I'm not running bio-fuel derived from my smoker drippings:)
malahhaor Aug 13, 2009 06:52 AM
i tried 89 and the bike wasn't doing very good at all, not very crisp on revs and acceleration and had hard time at idle. Died at red lights a couple times.
RPV-Hawk Aug 13, 2009 01:59 PM
I ran 91 because I thought that's what I was supposed to used. So I switched to 87. Right away I had problems starting the bike. after a few tankfuls, Went back to 91...start up problems went away.
Makes NO SENSE, since LOWER octane fuel should ignite easier than higher octane fuel. So the 87 octane should have started the engine easier than the 91...
Anyone have any idears?
the1bolton Aug 13, 2009 03:32 PM
Gal Darnet... I thought I read in my haynes manual that the bike needed 91 (R+M)/2... and I was sure of it. I thought half you folks were nuts. But there were so many posts saying that the bike was spec'd there so I checked it out... and I was wrong... 87 it shall be so long as I don't get knocking from the bike.
I double on the higher gas mileage at closer to 4k rpm. I started driving with cars that would get great gas mileage if you lugged them about but I definitely got ~6-8mpg better by sitting at a higher rpm on the bike. I haven't been pushing it to 4k on average though, more like 3.5k. Maybe I will try it out for a tankful!
Sorry folks... I just felt like keeping the 100th thread on gas octane alive. Just felt like it deserved it since it proved me wrong.
volcom Aug 13, 2009 03:42 PM
the fuel i use is 94 octane from petro-canada
REDVTR1000 Aug 13, 2009 03:56 PM
i could be wrong but on 91 you will run a little rich since the octane causes the fuel to not completely ignite. if you then rejet for 91 and mods and you switch to 87 you will run slightly lean and this can aggravate a pre-existing condition.
VTRsurfer Aug 13, 2009 05:01 PM
The octane of the fuel has nothing to do with how "easily" it ignites, since ignition is started by a spark.
Higher octane prevents detonation, which is a condition where 2 flame fronts collide eventually blowing a hole in your piston. The second flame front is not caused by the spark, but by a hot spot in the combustion chamber, like the edge of an exhaust valve.
Since the SuperHawk has only 9.5:1 stock compression, 87 octane is Honda's recommendation. Some new cars with direct injection can run on 87 with up to 11:1 or more compression, since direct injection provides a cooler charge.
Octane of gas in the 1920s was 60 to 70, but a Model A Ford had only 4:1 compression.
Just_Nick Aug 13, 2009 10:35 PM
Running a tank of 91 octane in the Superhawk, and I notice a severe lack in power. The motor is not nearly as responsive. I shall continue to run 87 octane.
CentralCoaster Aug 14, 2009 08:27 AM
Have you tried additive? I just run this stuff straight, engine is super quiet due to the hydrolocking compound they use.
http://www.nacd.net/images/foodsilverweb.jpg
COLE Aug 14, 2009 09:17 AM
i run 93 in everything i own, its gotta b lil better since it cost more haha i get better mpg on 93 and its j/ money ha
kshuck2 Aug 14, 2009 09:59 AM
89 E10
for those that dont know thats 10% ethonal... cheaper than 87 regular here in Nebraska... more power but less mileage because of the ethonal...
CentralCoaster Aug 14, 2009 11:13 AM
Originally Posted by kshuck2 (Post 231207)
89 E10
I think everything in California is E10 now, or close to it. Interesting that it's cheaper for you, because it costs more to produce.
kshuck2 Aug 14, 2009 11:41 AM
I'm definitely not an expert and could very much completely wrong... but I'm guessing it has to do with there being no oil refineries in nebraska, and a lot of ethonal plants... cheaper to produce than to truck in the gasoline...
k-d-williams Aug 14, 2009 01:31 PM
I voted race fuel, because there was no option for 100LL. I only run avgas in mine unless i'm out on a long ride away from home and then will use 93.
