View Poll Results: What fuel do you run?
87 grade
84
45.41%
89 grade
21
11.35%
91 grade
59
31.89%
Race fuel
3.24%
I'm from a European country, my ratings are different
8.11%
Voters: 185. You may not vote on this poll
Poll: What fuel do you run in your Superhawk?
Old Aug 12, 2009 | 03:36 PM
Just_Nick's Avatar
Who are you?
So I'm curious to know what you guys run in your SuperChickens. So let's see what people run.
Edit: It appears what is posted under the seat is 91 RON, which is equivalent to 87 grade here in the US.
Old Aug 12, 2009 | 04:04 PM
jbaxx's Avatar
Honducati
87
Old Aug 12, 2009 | 04:06 PM
REDVTR1000's Avatar
i used to be all "91 or 93 if you got it" and then i did some reading. there is no real gains to be had with a higher octane on our motor due to the very low compression. 87 is the ****. stop wasting money on the other stuff
Old Aug 12, 2009 | 04:08 PM
drew_c14's Avatar
87
Old Aug 12, 2009 | 04:18 PM
Just_Nick's Avatar
Who are you?
Oh, and I ran two tanks of 87, getting 41mpg on both, and I am now going to try 91 out.
We'll see. I kinda felt like I was getting a smoother idle with the 91.
Old Aug 12, 2009 | 05:20 PM
LineArrayNut's Avatar
I could ride in
the whole thing...
Originally Posted by Just_Nick
So I'm curious to know what you guys run in your SuperChickens. I know it says minimum 91 under the seat, but I know not everyone can read/likes following directions. So let's see what people run.
It doesn't just say 91; its 91 RON min. Makes a difference here in the US.
http://en.wikipedia.org/wiki/Octane_rating
87 is sufficient here in the US as a R+M/2; but since I often lug the beast, I run 89. Whatever. It's like oil. Or tires.
Old Aug 12, 2009 | 05:25 PM
Hotbrakes's Avatar
Yeah, we recently discussed this in depth here. Tried and proven in 3 local 'Hawks including my own that 87 gets the best mileage and runs just as well as the other stuff.
Old Aug 12, 2009 | 06:18 PM
Pimpsterbim1's Avatar
JAMES
I run premium (92 or 93 here in NW Ohio).. Its only 20 cents more a gallon compared to 87.. Plus my car "requires" premium, so I just run it in both.
Old Aug 12, 2009 | 06:36 PM
timdske's Avatar
timdske is on a distinguished road
I run 89. I haven't seen any gains with 93.
Old Aug 12, 2009 | 07:01 PM
CentralCoaster's Avatar
91 RON (Europe) = 87 octane (US)
Makes perfect sense. Riding my 'hawk requires me to wear a helmet, so I just wear it while driving my car too.
Old Aug 12, 2009 | 08:38 PM
RK1's Avatar
RK1
oh boy
Attached Thumbnails Poll: What fuel do you run in your Superhawk?-notagain.jpg
Old Aug 12, 2009 | 08:48 PM
autoteach's Avatar
My car runs diesel...
Anywho, don't lug the beast, let her breathe. Run it above 4k rpms and you might see better fuel mileage. Anything over 5 is diminishing returns. My buddy noticed it with his sv650 as well.
Old Aug 12, 2009 | 08:59 PM
Syclone's Avatar
Boosted
Originally Posted by RK1
oh boy
No ****, how many stupid fuel and oil threads do we need.
Old Aug 12, 2009 | 09:09 PM
Old Aug 12, 2009 | 09:43 PM
I run VP race fuel with two bottles of octane booster per liter... nothing but the best for my baby.
Attached Thumbnails Poll: What fuel do you run in your Superhawk?-fire.jpg
Old Aug 12, 2009 | 09:46 PM
killer5280's Avatar
I run 93 octane only because I have high compression pistons and she won't run good with lower octane. Before I installed them I ran 87 with no ill effects.
Old Aug 13, 2009 | 06:33 AM
FL02SupaHawk996's Avatar
Fastest Color
93 when I'm not running bio-fuel derived from my smoker drippings
Old Aug 13, 2009 | 06:52 AM
malahhaor's Avatar
malahhaor is on a distinguished road
i tried 89 and the bike wasn't doing very good at all, not very crisp on revs and acceleration and had hard time at idle. Died at red lights a couple times.
Old Aug 13, 2009 | 01:59 PM
RPV-Hawk's Avatar
RPV-Hawk is on a distinguished road
I ran 91 because I thought that's what I was supposed to used. So I switched to 87. Right away I had problems starting the bike. after a few tankfuls, Went back to 91...start up problems went away.
Makes NO SENSE, since LOWER octane fuel should ignite easier than higher octane fuel. So the 87 octane should have started the engine easier than the 91...
Anyone have any idears?
Old Aug 13, 2009 | 03:32 PM
the1bolton's Avatar
the1bolton is on a distinguished road
Gal Darnet... I thought I read in my haynes manual that the bike needed 91 (R+M)/2... and I was sure of it. I thought half you folks were nuts. But there were so many posts saying that the bike was spec'd there so I checked it out... and I was wrong... 87 it shall be so long as I don't get knocking from the bike.
I double on the higher gas mileage at closer to 4k rpm. I started driving with cars that would get great gas mileage if you lugged them about but I definitely got ~6-8mpg better by sitting at a higher rpm on the bike. I haven't been pushing it to 4k on average though, more like 3.5k. Maybe I will try it out for a tankful!
Sorry folks... I just felt like keeping the 100th thread on gas octane alive. Just felt like it deserved it since it proved me wrong.
Old Aug 13, 2009 | 03:42 PM
volcom's Avatar
volcom is on a distinguished road
the fuel i use is 94 octane from petro-canada
Old Aug 13, 2009 | 03:56 PM
REDVTR1000's Avatar
i could be wrong but on 91 you will run a little rich since the octane causes the fuel to not completely ignite. if you then rejet for 91 and mods and you switch to 87 you will run slightly lean and this can aggravate a pre-existing condition.
Old Aug 13, 2009 | 05:01 PM
The octane of the fuel has nothing to do with how "easily" it ignites, since ignition is started by a spark.
Higher octane prevents detonation, which is a condition where 2 flame fronts collide eventually blowing a hole in your piston. The second flame front is not caused by the spark, but by a hot spot in the combustion chamber, like the edge of an exhaust valve.
Since the SuperHawk has only 9.5:1 stock compression, 87 octane is Honda's recommendation. Some new cars with direct injection can run on 87 with up to 11:1 or more compression, since direct injection provides a cooler charge.
Octane of gas in the 1920s was 60 to 70, but a Model A Ford had only 4:1 compression.
Old Aug 13, 2009 | 10:35 PM
Just_Nick's Avatar
Who are you?
Running a tank of 91 octane in the Superhawk, and I notice a severe lack in power. The motor is not nearly as responsive. I shall continue to run 87 octane.
Old Aug 14, 2009 | 08:27 AM
Have you tried additive? I just run this stuff straight, engine is super quiet due to the hydrolocking compound they use.
Old Aug 14, 2009 | 09:17 AM
COLE's Avatar
Crash
i run 93 in everything i own, its gotta b lil better since it cost more haha i get better mpg on 93 and its j/ money ha
Old Aug 14, 2009 | 09:59 AM
kshuck2's Avatar
BeautyHawk
kshuck2 is on a distinguished road
89 E10
for those that dont know thats 10% ethonal... cheaper than 87 regular here in Nebraska... more power but less mileage because of the ethonal...
Old Aug 14, 2009 | 11:13 AM
Originally Posted by kshuck2
89 E10
I think everything in California is E10 now, or close to it. Interesting that it's cheaper for you, because it costs more to produce.
Old Aug 14, 2009 | 11:41 AM
kshuck2's Avatar
BeautyHawk
I'm definitely not an expert and could very much completely wrong... but I'm guessing it has to do with there being no oil refineries in nebraska, and a lot of ethonal plants... cheaper to produce than to truck in the gasoline...
Old Aug 14, 2009 | 01:31 PM
k-d-williams's Avatar
I voted race fuel, because there was no option for 100LL. I only run avgas in mine unless i'm out on a long ride away from home and then will use 93.
