theft recovery
theft recovery
hey guys I'm new and ended up buying a theft recovery. With 19k. setting in a garage since 2013 lol. There is no power at fuse block there is power at large wire on starter relay .The 4 wires coming out of it nothing. Any one have a wiring diagram ? Any help appreciated
Have a search as a colour scan is somewhere on this forum -- plus it could be worth in getting a hard copy of the Haynes Service Manual and/or the Honda Service Manual (again a downloadable PDF version is linked here)
Wiring diagram is in that.
Have you checked the fuses yet?
Box is near the battery.Theft attempt normally means some attempt to bypass the kew switch... so look for wire butchery there if fuses are good.
scotchrocket
01-04-2013 07:33 AM
thump
08-17-2004 02:11 PM
