SuperHawk Forum
-   Knowledge Base (https://www.superhawkforum.com/forums/knowledge-base-40/)
-   -   ignition coil help (https://www.superhawkforum.com/forums/knowledge-base-40/ignition-coil-help-22104/)
twidge Apr 5, 2010 12:27 PM
ignition coil help
hi folks i,ve had my 99 firestorm in bits all winter [contiuing the streetfighter build] and am putting it back together again.... trouble is i forgot to lable which wires go to the coil for the front cylinder and which go for the coil for the rear cylinder. i have green and a yellow for one and a green and a blue for the other..does it matter which goes to which as i understand it has a wasted spark anyway?
thanks folks.
4bangeranger Apr 5, 2010 12:55 PM
i will look at mine as soon as i get to my shop
maverick Apr 5, 2010 04:08 PM
Nope you should be able to hook them up however you'd like.
8541Hawk Apr 5, 2010 05:30 PM
actually they need to be on the right cyl. just because it is a wasted spark set up doesn't mean it fires on the other cyl. compression stroke.... I'll look the next time I'm out there or check the wiring diagram in the service manual.
twidge Apr 6, 2010 11:14 AM
thanks for the help
thanks for your help folks but i have looked at the wiring diagram in the manual and all it shows is the wires going to the coils but not defining which is which.
8541Hawk Apr 6, 2010 11:35 AM
Well take another look...... ;)
Ignition Coils:
#1 RR (rear) G & Y\Bu
#2 FR (front) G & Bu\Y
twidge Apr 6, 2010 11:59 AM
many thanks
many thanks 8541hawk.
my manual still dosent show which is which. but again many thanks for your help. i,ll go back in the garage now.
8541Hawk Apr 6, 2010 12:30 PM
No worries and mine shows it on the main wiring diagram (20-1) ;)
