Everything but ignition and start.
Ok, so I took the battery out Over winter. Put it back in fully charged.
Push starter button and nothing. With key on I do not have 12 volts to coils. I jumped the black wire w/red stripe to yellow wire w/ red stripe at the harness going to the switch and it turns over. I had years ago disabled the clutch wire. And I have verified kickstand switch is working also neutral safety is working correctly too. Where am I going wrong? |
Is the Off/Run switch on the right handlebar in the Run position?
James |
Headlight fuse OK? US version won't run without good headlight fuse in place.
