SuperHawk Forum
-   Knowledge Base (https://www.superhawkforum.com/forums/knowledge-base-40/)
-   -   Clutch hose mounting bracket (https://www.superhawkforum.com/forums/knowledge-base-40/clutch-hose-mounting-bracket-26323/)
wee nor Aug 8, 2011 11:17 AM
Hi guys, this may sound silly, after rebuilding the whole bike, I cannot find a suitable mounting bracket in my small parts "still to fit" box to clamp the rubber hose to the lower frame ! Help anyone :D Cheers.
scottiemann Aug 8, 2011 12:04 PM
cant find it... zip tie it...
Old Yeller Aug 8, 2011 12:51 PM
if it's what I'm thinking of, it was a fancy zip tie that was right in the area of the lower rear bolt of the fairing. There were a couple different wires and such bundled together. A standard zip tie should do the trick.
8541Hawk Aug 8, 2011 01:38 PM
3 Attachment(s)
Well I don't have a close up of the hangers hopefully these pics will help.... you might have to download the image and blow it up a little but those are all I have of the clutch line
Attachment 12291
Attachment 12292
Attachment 12293
Also the front hanger is the reusable zip tie that the wiring harness passes through in the front and the rear hanger mounts with the lower fairing bracket. ;)
wee nor Aug 9, 2011 02:23 PM
Your last picture has jogged my memory........and found the plastic clip. Thanks guys for all your help.:cool:
