SuperHawk Forum
-   Knowledge Base (https://www.superhawkforum.com/forums/knowledge-base-40/)
-   -   Bafflectomy and backfireing?? (https://www.superhawkforum.com/forums/knowledge-base-40/bafflectomy-backfireing-23332/)
hedgehog Jul 30, 2010 08:03 AM
Hello I'm new to the forum. I recently finished a bafflectomy on my 98 superhawk. I drilled one side with a hole saw back in 2004 and chickened out so I fixed it with a steel ring and some JB weld and rode the rest of that year with no troubles. Well in 05 my daughter was born and the bike got put away due to money issues. Well I decided that this year i am gonna ride. I got her running again clean carbs, new plugs, and new battery. Thing is the ring fell off the back of the exhaust so I went ahead and drilled the other side and pulled them out. It seems to run fine but, but it backfires some when running at a steady rpm, and backfires alot when decelerating. Anyway do I need to rejet, or is there a fix for it. Or should I just deal with it until I decide to buy new cans.
8541Hawk Jul 30, 2010 08:11 AM
If you disable the PAIR system the backfiring should stop.
RWhisen Jul 30, 2010 08:15 AM
And don't forget to get some of those sweet block off plates sold by one of the members here!
SH PHIL Jul 30, 2010 08:16 AM
I just bought a '98 Hawk that has had a bafflectomy. I don't know to what extent the baffles were modified but the previous owner told me he had them gutted. The bike exhibits the same backfiring as described during decel. I plan to remove the PAIR, but is the backfiring (popping) during decel harmful or is it more of an annoyance? Or in other words, should I do disable the PAIR ASAP or at my leisure? THanks guys.
hedgehog Jul 30, 2010 08:16 AM
cool thanks, I have read some about the pair system, guess I have something to do now on my day off lol. And do you have any pics of those sweet block off plates???
skoshere Jul 30, 2010 09:04 AM
your flux capacitors in the exhaust canister are broken. You need to spend about 6 grand to have them fixed.
No seriously, removing your PAIR will fix the majority of your backfiring.
RWhisen Jul 30, 2010 09:05 AM
Here they are:
https://www.superhawkforum.com/forum...highlight=pair
lazn Jul 30, 2010 09:14 AM
No rush, it's just noise. If the baffles are there, the unburned fuel still gets burned by the PAIR process you just don't hear it.
nothing Jul 30, 2010 10:16 AM
when your riding and it's backfiring, that's a lean condition and not good. on deceleration that is the PAIR thing everyone is talking about.
SH PHIL Jul 30, 2010 11:53 AM
yeah there's no backfiring under throttle at all. just when i roll off it starts to sounds like popcorn. thanks for the info guys.
nothing Jul 30, 2010 12:38 PM
Huh? I was responding to the OP.
but in your case, decel popping = PAIR
pwshadow Jul 30, 2010 12:52 PM
Some times I use the PAIR pop to scare the cars behind me;) I did it and my friend on a cbr said he wished he could make 6 inch flames come out of his tail pipe.
hedgehog Jul 30, 2010 08:06 PM
Thanks guys, I spent most of the day chopping off the rear fender, cleaning crud and I took care of the pair system. It took care of almost all of the backfire. I think it backfires when I have the choke on still as I ride to work in the morning and it is kind of hard to get warmed up in the mornings. I took it out when I got done tonight and almost all the decel backfire is gone. But I must have bumped my light to hard as the low beam doesn't work now since I put the front end back together. Oh well I thanks again for the help.
