Why Should I Buy a SuperHawk?
Old Jul 27, 2004 | 02:53 PM
cdyer77's Avatar
cdyer77
In my opinion, in short I love my hawk. Coming from many inline 4's over the past ten years, once I got on the v-twin i was in love. The torgue, the sound, the power is abudant.
You are correct in assuming the shortcomings of the stock suspension. I'm a light guy (170 lbs) and the front springs were too soft for me. I ride pretty aggresive and do a few track days a year, so upgrading is a definate! Same goes for the rear.
If you plan on buying used try to find one already set-up in the suspension dept.
Other then the poor suspension, I have no complaints. I can ride for 5-6 hours without any buzz at the bars or soreness in the seat or back.
I would also recommend aftermarket exhaust. It really brings out the sound of the v-twin. There are several mfg.'s that make exhaust that sre not obsenely loud.
I also put stainless brakes lines on my hawk just to help the brakes out a little. They seem to me to fade alittle after hard use. The new lines improved this, but they do still have a little fade to them after hard usage.
The mirrors you may as well throw in the trash because you can't see anything past your elbows. R1 mirrors seem to fit on pretty well and have longer stems.
Other then that stuff. Like I said before...I Love my Hawk!
Old Jul 27, 2004 | 03:07 PM
Random's Avatar
Random
Re: Why Should I Buy a SuperHawk?
I love the rattle of the dry clutch, and the sound of Desmo valve V-twin engines at full throttle. *drool* But I just couldn't justify the cost vs HP ratio. The SH wins that battle hands down.
Handling, the stock 900SS will be better than a SH in stock form, but with the $$$$ you save, you can fix the SH suspension.
For rear shocks, there's Fox, Ohlins, and Penske, roughly in order of cost. The stock rear shock works okay as long as you're under 180-200 lbs. Over that and you'll WANT the upgrade. Even if you are a smaller guy, the adjustability offered by the aftermarket units allows for freeway soft and track hard with some simple adjustments.
For front suspension, there's Traxxion, Race Tech, then a whole host of front end swaps. (roughly in order of cost). The front end dives somewhat under braking, and compresses quickly under fast/sharp bumps. And upgrade does wonders for feel and confidence.
The suspension can be fixed fairly easy(but not free), and some exhaust/jetting mods can turn it into a decent performer.
With the stock foot pegs, and stock low exhuast, it does have some ground clearance issues for severe cornering, but if you "hang off" you'll be fine at 9.5/10ths. Rear sets and high mounts/underseat would fix the problem.
I personally love my SH and would only replace it for either a Ducati 998S or R, or a Aprila Tuono Factory Race.
Old Jul 27, 2004 | 03:12 PM
faz's Avatar
faz
faz
first off, I admire your respect for residential roads and your thinking to go quiet... I have always been a fan of stock pipes and their nice sound (or lack thereof). However, I must say, I too like a growling v-twin that is not too loud.
As for the superhawk, I have had mine for the last 4 months or so. I am quite happy with it overall. Tons of torque low end, good power, and handling is ok but can definitely use improvement. I am not a hard racer type, and my street rides are still very average paced (10-20 mph over the speed limit in twisties.) overall, for my purposes, I love the bike and it does more than just fine.
Mine came with Heli bar raises installed on it, as well as mirror extenders ($25 or so from rrmotorsport.com ) I put a MUCH needed steel brake lines and upgraded the brake pads on the front. (stock brakes are NOT adequate for a bike with this much power/torque.)
As I said in one of my posts on another board, I believe superhawks are one of the best bang for the buck. Go to vtr registery and you will see tons of them with 30k or more reliable miles on them!, so buyin one with 10k miles or so on it is like buying them new.
Old Jul 28, 2004 | 07:51 AM
Random's Avatar
Random
Only your first few rides will really be able to answer that. Some folks like the stock suspension, but some can't stand it. Usually the more "sporting" folks are the ones that look for the upgrade.
Old Jul 28, 2004 | 10:13 AM
mamisano's Avatar
Super Moderator
mamisano is an unknown quantity at this point
As my first bike back in 2001, the stock suspension was fine for me. With more agressive riding in the past 2 years, the shortcomings are very noticable. The front end dives at the hint of brake use and during turns the bike wallows. Tires have made a tremendous improvement, but I will be going with new forks/valves in the front and then as money affords, a new rear shock.
Brakes are another issue that can be fixed relatively easily. As was previously stated, SS Lines and HH pads go a LONG way to help braking power and reduce fade. Along with those, I also installed a master cylinder from a 929RR which increases piston size. The modification increases the sensitivity of the front brakes, requiring less lever travel but more pressure. All I know is that I have no problem with 2 finger braking all day long which could not be done with the stock setup.
The bike does way a bit more than your GT and is is larger. Nothing is going to overcome the law of physics, but the SuperHawk is very slender and nimble machine in its own right.
You should try hooking up with a local SH owner and swap bikes for a ride. This way you can judge for yourself. Personally, I don't think you'll regret it... and coming from a smaller V-Twin will make the transition that much easier and more enjoyable.
Good Luck
Circuit_Burner
Oct 14, 2013 06:44 PM
RCVTR
Jun 5, 2013 05:24 PM
wasmeneh
Apr 10, 2010 06:09 PM
j shizzy wizzy
Dec 27, 2009 07:11 AM
motojoe
Aug 10, 2009 10:51 AM
