What to look for in a used Superhawk
Looking at buying a 1998 Superhawk. 59000 km, red, aftermarket high mount slip on cans (Delkevic I think), Corbin seat. Rest appears to be stock. Bike looks clean but i haven't seen it yet. Would like some comments from the group on the general reliability of these old Superhawks and any items I need to look for when I see it. Obviously I'll inspect the tires, chain/sprocket, fork seals, brakes, etc). I am aware that the auto CCT's on these bike are prone to failure and need to be changed to manual CCT's. Also aware that the R/R's are prone to failure (replace with Mosfet R/R ?). Anything else?
I'll ask about when the valve clearances were checked last but too many owners are clueless about this, so I'm not expecting much of an answer. Looking forward to your comments. |
You've covered the big ticket items. The rest is just standard stuff you'd look for in any motorcycle. I always tried to feel the steering head bearings for loose adjustment and/or worn races.
I'd also maybe put a flashlight in the tank to inspect for rust and check the airbox to see what state of goo the breather filters are in.
I am new to the VTR, have just bought a 2001 model here in NZ.
For anyone interested, I have just received 2 x 14520-MBB-013 cam chain tensioners for about $49 USD each delivered to NZ, pinky / flesh coloured paint dot on them, should be the latest incarnation of the dreaded auto cct. Company is partsouq.com And as an adder to the email I have dam well pulled the thin spring set key out of one of them...hopefully I can re-set this unit to closed piston position.... I should learn not to f--k with things. |
Originally Posted by trollope
(Post 417100)
yes indeed, its how Mr Honda made it. My oldschool mechanic for over 40 years says thats how they should be, and manuals can be quite hard to set according to him.
(Post 417104)
If you are willing and or believe this is the way, there is this alternative to the manual vs auto compromise. I did the mod more than a year ago. So far I haven't found myself on the side of the road wonder what happen to the engine. As always YMMV.
CCT (Cam Chain Tensioner) Fail Safe Mod. (aka Stopper Mod) - VTR1000.ORG |
Well I didn't buy the bike. Mechanically it was fine, as far as I could tell. But the fairings were in bad shape, all scuffed up, several cracks, and held together with tie wraps through holes that one of the owners had drilled. I didn't expect the fairings to be in prestine condition, but they were just in too bad a shape for my liking. I would have to purchase a complete fairing kit (and decal kit) for the bike. I passed.
Sounds like a smart decision. Can you find any on your local FBMP?
(Post 417124)
Don't kid yourself, you need a SuperHawk.
Originally Posted by VTR1000F
(Post 417127)
I did that CCT fix what "xeris" did. And think it is really quit clever. I thought about doing a video...but everybody seems to like the Manual CCT....so I did not bother. I have checked the adjustment to make sure it is good....so far.
It should be fail safe...just if the adjustment fails, the chain will be noisy....and you will need to fix the spring adjustor. I am paranoid about over tightening the manual CCT's. I prefer the auto-adjust idea. IMO. |
I ended up passing on the Superhawk. As I mentioned in my previous post, the fairings were in terrible shape, all cracked, held together with tie wraps and tape. I'd still like to buy a Superhawk at some point if one comes along that is in my price range. Haven't found it yet...
Blah, blah, blah. You need a SuperHawk.
(Post 417174)
Also, after you get a good one, don't sell it. |
(Post 417174)
Originally Posted by Hangfly
(Post 417175)
Yes you do. Its quite obvious.
I just got a 1999 Superhawk that needs TLC. Last registered in 2013, it has a different gas tank that is immaculate inside, but has bad clutch master cylinder, non responsive rear brake, ignition switch that lacks the key lock (thief recovery??), different seat cowl (white vs factory yellow fairings), and seller said carbs must be cleaned. It heard about the need to install manual CCTs, but I have not heard of "R/R". What is this? Thanks!
Originally Posted by Oldrider78
(Post 417462)
Regulator/Rectifier, of course! Thanks for the reminder. Any suggested brands? I seem to recall that some OEM are not as good as aftermarket components.
| All times are GMT -7. The time now is 05:05 AM. |
