valve stem seals
So far OEM Honda is the only seal I can find....Is anyone aware of an aftermarket supply?
AV |
Hey man, just wanted your opinion about my 2015 vw jetta 1.8TSI. My car burn about 1L/1000km of oil and I have recently replaced my PCV valve which was initially just a bit worn out and not really damaged according to the mechanic I went to. However, the problem still remains unsolved. I was informed that there were no visible leaks anywhere in the engine bay and the turbo. Do you think this excessive oil consumption could be due to worn valve seals? please help.
snaptube vidmate |
Clogged oil return line from turbo.
Av |
Also how many miles, and what oil do you use?
Originally Posted by Alikxo
(Post 413481)
:admin: |
